1978 - 1996 Big Bronco
351W nightmare
Old Aug 28, 2018 | 01:24 PM
CSH88's Avatar
CSH88
351W nightmare
My son has a 95' Bronco with a 351. He has absolutely no mechanical ability, so I have been given the task of fixing it. The idle gets rough at times and the ck engine light will flash then go off. When driving, it will drive normal for a few miles and then feels like it dropped a couple cylinders with no pwr. From there on it will do this intermittently unless it stalls all together. I managed to repair a crack in a vacuum line. I have no idea if there are more leaks, or if its even the problem.
Old Aug 28, 2018 | 02:41 PM
Redark1's Avatar
Redark1
welcome to the group first off. you probably need to start with the check engine codes. if your planning on spending time with this then go buy a INNOVA code reader from the parts store. there are many things or might be just a few things wrong but with out the codes you cant really do anything right.
first things are tune up or check the ignition parts. fuel filter. air filter and stuff like that. go from there. cracked vacuum lines need to be replaced too.
Old Aug 28, 2018 | 03:15 PM
Kemicalburns's Avatar
Kemicalburns
whats the history on the vehicle? get your son involved as well since you cant be expected to do everything especially given the rig is 20+yrs old. getting all the vacuum lines replaced would be a good step, checking codes like mentioned. and also a tune up. Change the spark plug and wires one at a time so the order doesnt get mixed up. run a standard autolite/motorcraft copper plug gapped to .44
keep us posted
Old Sep 5, 2018 | 09:55 AM
CSH88's Avatar
CSH88
Thanks, replaced lines with no help. Next will start tune up.
Old Sep 7, 2018 | 02:54 AM
WhëëlMå1's Avatar
WhëëlMå1
If you get the engine lights, read the codes. Even if you don't want to buy a reader, go to an auto store and have them do it. There will be important data there to start your troubleshooting.
Old Sep 7, 2018 | 08:39 AM
phillips91's Avatar
phillips91
Take it by somewhere like advance or autozone and have them run the codes. They do it for free. It may be something simple and cheap to fix. Throwing parts at it with no clue what is wrong with it is going to lead to an expensive nightmare pretty quickly.
Old Nov 20, 2018 | 09:06 AM
CSH88's Avatar
CSH88
keep us posted
Sorry for the long delay. I purchased a 01 Honda for him to drive while I fiddled with the Bronco when I had time. Update: Son totaled the Honda. Therefore, I had no choice but to take Bronco to a local shop. I think all they did was swap parts and put my acct in the negative. Before taking, I changed plugs, cap and rotor with no effect. The shop changed distributor and coil with no change. So, I ordered an ECM. They replaced it and it runs better. But, after warm up, check engine light flashes and loses power. So, after $900 I'm still thinking about the TPS. Any thoughts?
Old Nov 20, 2018 | 10:21 AM
rla2005's Avatar
rla2005
Pull the codes.That Check Engine Light (CEL) is trying to tell you something.
Warm up the engine then do this (use a paper clip or length of wire): How to Run a Self Test
Your truck will display 3 digit codes. Please run the Key On Engine Off (KOEO) tests and Stored Code display. List any codes, by number, and when they were displayed.
Or invest ~$20 USD on a code reader. It will pay for itself many times over. Highly suggest the Innova/Equus 3145. Great tool.
Old Nov 20, 2018 | 11:53 AM
Kemicalburns
perhaps the catalitic converter is shot or plugged. fuel pressure loss could also be an issue while driving although neither of those would trip the CEL
Old Nov 23, 2018 | 12:05 PM
vjsimone's Avatar
vjsimone
Amazon Amazon
Old Nov 23, 2018 | 12:18 PM
Tedster9's Avatar
Tedster9
Along with a code reader, suggest a mechanic's vacuum gauge, for about the same price. They are simple to use and provide a lot of information quickly to include a restricted exhaust, that might be caused by a defective catalyst.
Old Nov 29, 2018 | 04:57 PM
One eyed Jumpin Jack's Avatar
So, you're throwing money at it and haven't even checked the codes that will tell you exactly what the problem is? Then took it to a shop that wasted even more money without checking the codes? Do that poor truck a favor and sell it before your kid with "absolutely no mechanical ability" or his dad with apparently not much more mechanical ability than his son ruins it. Or maybe try CHECKING THE DAMN CODES!!!! as instructed.
Good Grief. All you need is a paperclip and a notepad.
BigBair
Modular V10 (6.8l)
44
Oct 25, 2016 09:08 PM
jakeupowens
3.8 & 4.2L V6
Apr 16, 2014 08:13 PM
Famousff
Apr 1, 2014 11:01 PM
fstbck1970
Aug 22, 2013 08:19 PM
ADSf100
18
Sep 11, 2009 12:15 PM
