Sponsored by: Auxito
transmission problem
Old Aug 28, 2018 | 12:36 PM
pikebishop's Avatar
pikebishop
hello there I have been reading this forum and using its information to help me with my 2001 f150 . recently I started having a transmission problem this truck has the 5.4 is four wheel drive and has the 4r70w transmission symptoms are as follows intermittently the truck will rev higher than normal before taking off once engaged it shifts through the gears normally and once in converter lockup cruises fine sometimes when sitting at a light in drive waiting for green the truck will make a thunk and try to engage in foreward when this happens sometimes the truck will stall sometimes it releases. the truck has 250,000 miles on it and the previous owner said he had the transmission rebuilt at 155,000 fluid is not very old replaced at 210,000 no leaks fluid is clean and smells fine I am hoping somebody might tell me this could be a sensor, solenoid or other issue that I can fix myself rather than spending 3000 for a trans rebuild I am very experienced at working on cars and am not shy about repairing things myself but know very little about automatic transmissions thanks for any advice.
Old Aug 28, 2018 | 01:08 PM
pikebishop's Avatar
pikebishop
no codes pending or present
Old Aug 28, 2018 | 01:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Put a 0-350 PSI gauge in the test port on the driver's side of the transmission. Watch what the pressure does when it acts up. There could be an internal pressure leak.
Fleshwound99
Jul 18, 2019 01:16 PM
occupa
27
Feb 10, 2017 10:52 AM
wildstang
Aug 21, 2015 09:30 AM
A star
Aerostar
Mar 5, 2012 04:39 AM
Kenny Bonnell
1997 - 2003 F150
Jun 26, 2005 08:38 PM
