??AOD in F250 ???
Old Aug 19, 2001 | 08:06 PM
leharrison's Avatar
leharrison
??AOD in F250 ???
Hi all,
I am putting an AOD transmission behind a 300 6cyl EFI in a 1988 F250. My question is, Are there any special wiring hookups for the lockup torque converter? Is it operated by the onboard computer and if so what wires need to be run? The truck in question previously had a 5 speed. Any other advice would be appreciated concerning the conversion.
Thanks.
Larry
Old Aug 20, 2001 | 02:43 AM
brett_d's Avatar
brett_d
??AOD in F250 ???
I assume you are putting in a AODE not a AOD???
Old Aug 20, 2001 | 07:59 AM
leharrison's Avatar
leharrison
??AOD in F250 ???
I have not actually done anything as yet. I am seeking info on what is involved. I am very ignorant of the OD transmissions. Does the AOD not have an electronic lock up torque converter? If not, then would it not be just a simple swap. I wanted to go with an E4OD as I have read that it is the better of the transmissions but I am trying to avoid the big expense of the electronic hook up kits. I understood that the AOD needed no electronic hook up but then I have spoken to some friends who are "wanna be" experts that say that I must still computer controls for the converter. I am confused. Do I or Do I not need to hook in the electronics on an AOD? Thanks
Old Aug 20, 2001 | 05:21 PM
Torky's Avatar
Torky
??AOD in F250 ???
No electronics in an AOD. Only wiring is for the Park & Neutral start safety switch.
Old Aug 20, 2001 | 08:49 PM
leharrison's Avatar
leharrison
??AOD in F250 ???
Thanks
Old Aug 20, 2001 | 09:03 PM
frenchie's Avatar
frenchie
??AOD in F250 ???
budrizer
17
Jun 15, 2010 11:36 PM
lshort
1983 - 2012 Ranger & B-Series
13
Jan 19, 2008 12:07 PM
Larry Murray
16
Apr 7, 2007 03:31 PM
leharrison
Aug 20, 2001 05:19 AM
Larry
Nov 19, 1999 11:51 PM
