Ford A/C testing
Old Nov 19, 1999 | 02:41 AM
Larry's Avatar
Larry
Ford A/C testing
Hello, guys: I've got an '88 F-250 with A/C & when I turn it on, the clutch won't engage. I found the pressure switch & disconnected it & used a jumper wire to by-pass the switch & the compressor clutch kicked in. Now my question--how do I test the switch to see if it's faulty or check the refrigerant pressure to see if that's the problem ?? Any ideas ?? Thanks, guys !!
Larry
Old Nov 19, 1999 | 11:25 AM
Phillip Guidry's Avatar
Phillip Guidry
Ford A/C testing
It sounds like you don't have an a/c gauge of any sort so just by a new switch which should be around $10-$15, rather than $60 or more for R-12 gauges & 134a gauges go at least $100 for generic ones.After all, if it is low on freon,it could be the switch that leaked it out or is part of the leaks you have,so replacing it is gonna happen sooner or later.
Phillip
Old Nov 19, 1999 | 02:36 PM
Dewy's Avatar
Dewy
Ford A/C testing
I think I am having a similar problem with my AC. It works "Sometimes" so i don't think it's the coolant but the switch. Where is it located? I haven't had a chance to look for it yet. Thanks!
Old Nov 19, 1999 | 05:05 PM
Larry's Avatar
Larry
Ford A/C testing
Dewy: You didn't say what you're driving but if it's a Ford pick-up, the switch should be located on a black canister about 4" across & 7"-8" tall on the pass. side close to the firewall.
Larry
Old Nov 19, 1999 | 05:07 PM
Larry's Avatar
Larry
Ford A/C testing
Philip: Thanks for the advice, I'll try it.
Larry
Old Nov 19, 1999 | 11:51 PM
heb1967's Avatar
heb1967
Ford A/C testing
WVVan
32
Apr 1, 2017 04:56 PM
mantta
Electrical Systems/Wiring
Aug 10, 2011 07:30 AM
Tomlin
Jul 2, 2011 09:24 PM
bryanj
Mar 22, 2010 10:40 PM
Larry85355
Jul 3, 2009 01:49 PM
