Check Engine Fault Codes
Old Aug 25, 2018 | 08:33 AM
EconolineFan's Avatar
EconolineFan
A mechanic pulled some codes on my 95 E150 with the 5.0 V8. They are:
1) 122-throttle position sensor low (possible ground or open circuit)
​​​2) 125 - throttle position voltage lower than expected-fuel control
3) 157 - mass air flow signal is low/grounded
The van has new spark plugs, wires, and cap/rotor. It sometimes runs rough and if you press the throttle from a standstill it will hesitate. When it is running rough I can sense a sulfur type smell. I don't want to spend even more money at a mechanic and was wondering if I should try throwing a new TPS and MAF sensor at it? There were other codes found but they pertained to the A/C evaporator and torque converter clutch.
Old Aug 26, 2018 | 07:58 PM
wirelessengineer's Avatar
wirelessengineer
Before you throw parts at it, you might want to make sure that the wiring is okay. Verify that you have a good ground for both, too.
f100beatertruck
15
Dec 12, 2023 01:53 PM
1986OhioF150
Jan 28, 2015 08:58 PM
normaltype
Aerostar
Jul 25, 2007 11:45 PM
nightshifter
Aerostar
66
Jul 5, 2007 10:12 AM
Wakeboarder141
1978 - 1996 Big Bronco
19
Oct 31, 2004 11:50 AM
