It was running like crap a while ago. It was idling irratically (reving out of control and wouldn't kick down) Hasn't done that in a while and seems to run decently now, but the engine light turns on and off while driving.
I would clean the MAF sensor with TB or electrical parts cleaner. Then just check the connections and make sure they are snug. As for the TPS, if the TPS ever triggers a code, check the wiring and connectors to make sure they are good and that there is no corrosion. If a visual inspection comes out ok, get a new TPS. They are not expensive, and they could be triggering the MAF code as well (very unlikely, but still possible.)
We had an e-350 where the TPS went out, and it started to show signs that it wasn't responding well with the throttle in certain positions. To get a response, you either had to use less throttle or more, since there seemed to be a dead spot. When it triggered the code the following day, the van was nearly undriveable. Trying to get it to the parts store was a challenge. It took nearly 30 seconds to get to the 40 mpg speed limit. The sensor was fairly easy to replace. I compared the new ones resistance to the old one right there in the store. The resistance at idle on the old part was greater than the resistance at WOT on the new one. At WOT on the old one, the resistance was about 10 times greater than the WOT resistance on the new part. And there was a dead spot where the meter went out of range.
Van IS almost 20 years old LOL. I will just replace the TPS as that was my suspicion in the beginning. I'll also clean the MAP sensor and check vaccuum lines.
O, my apologies, a MAP sensor is different than a MAF sensor. A MAP sensor should not be cleaned. It either works or it doesn't. It measures the vacuum in the intake manifold to determine information about engine load, and when combined with the intake temp sensor and coolant temp sensor, it can give good information about air density.
