ELC in V10
Old Aug 24, 2018 | 10:34 PM
jazz77's Avatar
jazz77
ELC in V10
I'm fixing to do a coolant flush in my 7.3 Ex and realized the 6.8 hasn't had one in at least 8 years. I already have 6 gallons of ELC, would I be ok grabbing a couple more gallons and using it in the 6.8? I've searched around but haven't found a real answer . Thanks in advance
Old Aug 24, 2018 | 11:20 PM
pirate4x4_camo's Avatar
pirate4x4_camo
There are some many pesky details to OAT and HOAT coolants that there is no one size fits all answer to that question.
your best bet is to look up the ford spec in your owners manual for coolant and then look on the container of the coolant you are considering. ( same holds true for motor oil but you need to get the current specs from ford since motor oil specs have changed in the last few years as emissions have gotten tougher )
Old Aug 24, 2018 | 11:48 PM
pirate4x4_camo
Verify your manual calls for WSS-M97B44-D2
if so shell list their ELC NF as compatible.
https://rotella.shell.com/media/2015...-free-elc.html
fwiw.... I found not even all ELC were comparable with the 7.3. Its all in the details
Old Aug 25, 2018 | 07:14 AM
01__Excursion's Avatar
01__Excursion
Helpful?
Maybe there should be a quick reference link in the Tech folder, and this added to it?
http://www.fordservicecontent.com/Fo...G1746490&div=f
File Type: pdf
Old Aug 25, 2018 | 09:17 AM
jazz77's Avatar
jazz77
I guess I should have specified that it is the Shell Rotella ELC that I have on hand. I know what the book calls for, what I was asking is if there is an issue using ELC instead.
Old Aug 25, 2018 | 10:49 AM
pirate4x4_camo
my point exactly. I specified Shell Rotella ELC NF as that one that meets the spec, You state Shell Rotella ELC and it does not meet ford spec. Shell makes at least 4 diffrent formulations of “ extendeded life coolants” Some meet ford spec and some do not. ( same goes with oil. )
https://rotella.shell.com/products/l...e-coolant.html
Old Aug 25, 2018 | 05:11 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by 01__Excursion
Helpful?
Neither link applies to the Excursion. One link is from the 2016 owners manual and the coolant PDF is for 2018 and 2019 MY Fords.
I have seen and even referenced the Ford coolant chart that covers our MY rigs, but I've never wanted to post it in the tech folder because Ford has never recommended a Heavy Duty OAT Extended Life Coolant for the 7.3L PSD (even though that's the coolant spec International recommends for the engine), and that can confuse a person.
Stewart
Jaime74656
Jun 21, 2018 07:34 PM
Twonky
Oct 1, 2017 09:29 AM
Diesel Man 03
29
Oct 7, 2012 09:42 PM
favarcat
Modular V10 (6.8l)
Jul 6, 2005 10:55 PM
howarda
Modular V10 (6.8l)
13
Dec 4, 2004 06:32 PM
