97 7.3 problems
Old Aug 24, 2018 | 05:19 PM
97 FORD POWERSTROKE's Avatar
97 FORD POWERSTROKE
97 7.3 problems
brought the truck used 118,000 miles on it,had fuel leak,thinking that was the problem with in running bad.(NOT) REPLACED FUEL PUMP,OIL,FILTERS IPR,ICP.CAM SHAFT SENOR,WIRING HARNESS FOR FUEL BOWEL,PASSENGER SIDE VALVE COVER GASKET, NEW PLUG INJECTOR WIRING HARNESS,IDM,PUT ON SCANNER EVERYTHING CHECKS OUT OK NO CODES,BUT IT ACTS LIKE ITS MISSING AND HAS A CHATTER,ONCE WARMED UP STALL AT HIGH IDLE OR WHEN YOU PUSH THE CLUTCH IN IT STALLS. ANY SOLUTIONS, THANKS
Old Aug 24, 2018 | 08:22 PM
867.309's Avatar
867.309
What scanner? Will it do live data? CPS sync. ICP, IPR, 12V, 5V
Scanner must be j1850 PWM compatible.
Got a fuel pressure gauge?
Does the clutch kill it like a kill switch?
J_booras
Mar 16, 2017 10:03 PM
dieselx4
Dec 15, 2012 04:33 PM
andercontracting
Sep 30, 2012 02:39 PM
sparke454
82
Feb 7, 2012 07:12 PM
Mel G
Jun 5, 2006 11:59 AM
