7.3 runs rough
Mar 16, 2017 | 02:11 PM
7.3 runs rough
I have a 97 7.3 with 119k on it. The truck will run great and then start to miss horribly then shut down. Parts replaced within the last 6 months are valve cover gaskets, ipr, cps, 1 new injector, and a new turbo.
Any help would be greatly appreciated
Mar 16, 2017 | 02:35 PM
fuel pressure?
more than 1/4 tank of fuel?
change fuel filter in last 10k miles?
use ford IPR and CPS?
Mar 16, 2017 | 02:42 PM
Yes. New fuel pump as well. Forgot to add that in. Everything I put on the truck is motorcraft
Mar 16, 2017 | 05:35 PM
Have you tested the idm? What about the oil level in the hpop?
Mar 16, 2017 | 09:12 PM
Yes. The idm is good and so is oil pressure. Fuel pressure is a little low though.
Mar 16, 2017 | 09:16 PM
Check your in tank screens to see if they are not clogged up.
Mar 16, 2017 | 09:53 PM
You said the VC gaskets were replaced, but how about the under cover harnesses? how do the engine side plugs to the VCs look? Any melted connectors or burned pins?
Mar 16, 2017 | 10:03 PM
when does it run rough? all the time? When it's cold? In a certain gear? any other clues would be good help
mcachran
Jul 28, 2013 08:40 PM
huntersmith57
Jun 5, 2010 10:43 AM
fordmerc
Jan 12, 2010 08:35 PM
Mel G
Jun 5, 2006 11:59 AM
hott-rodd
22
Dec 12, 2005 02:49 PM
