Dieselx4
Old Dec 11, 2012 | 08:40 PM
dieselx4's Avatar
dieselx4
Dieselx4
hello all. I have a 97 f250 7.3 powerstroke. it cut off on me like it ran out of fuel. got it restarted and drove fine for a week. did the same thing again. got it restarted. next day quit again no restart. i have changed the manual fuel pump,CPS,EBPS with no luck. any ideas?
Old Dec 11, 2012 | 09:16 PM
Talyn's Avatar
Talyn
Clogged FPR.
Old Dec 11, 2012 | 10:37 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Where'd you get the CPS from? The regular parts stores ones have a habbit of lasting about a day.
Old Dec 12, 2012 | 06:25 AM
427 fordman's Avatar
427 fordman
Or not working at all....
Old Dec 12, 2012 | 06:55 AM
91 Dually's Avatar
91 Dually
Same thing happened to mine. Turned out to be the IPR.
Old Dec 12, 2012 | 07:31 AM
madpogue's Avatar
madpogue
Does it cut out while you're rolling? If so, did you happen to notice if the tach dropped to zero immediately, or did it keep reading the engine RPM as it was coasting down?
Old Dec 12, 2012 | 10:01 AM
fordpride's Avatar
fordpride
How much fuel was in the truck when this happened ?
Old Dec 15, 2012 | 09:28 AM
dieselx4's Avatar
dieselx4
dieselx4
it was full of fuel. i have changed the Ipr. got it running yesterday once for 13min and once for 5 min. when it quits it just shuts off. also when it was running i tried to hook up my scan tool and it quit immediately.
Old Dec 15, 2012 | 09:46 AM
Ford4Life7.3
Are you able to rev it up when you get it to run, or does it die when you try to rev it?
Old Dec 15, 2012 | 09:59 AM
Talyn's Avatar
Talyn
I'm still going for clogged FPR.
Old Dec 15, 2012 | 10:11 AM
Ford4Life7.3
I was going to say the screen, which is why i asked about it revving up. Of course, the CPS is still on the table right?
Old Dec 15, 2012 | 12:13 PM
Talyn's Avatar
Talyn
FPS cleaning = Free.
CPS = Cost money.
Always start with free stuff and rule it out.
KISS first, spend money later.
Thats my method anyways.
Old Dec 15, 2012 | 04:33 PM
madpogue's Avatar
madpogue
Sounds like you tried some generic OBD-II scanner. Our trucks aren't standard OBD-II, and generic scanners will do that. You need a Snap-On MT2500 or Modus, AutoEnginuity software, or an AeroForce Scangauge.
Swat_Medic
May 13, 2018 02:20 PM
WoodBoss
Oct 1, 2015 09:39 PM
dcelrod
Sep 24, 2014 05:15 PM
15 and 92 Dad
Jan 29, 2008 05:04 AM
Mel G
Jun 5, 2006 11:59 AM
