Carburetor question
Old Aug 24, 2018 | 05:08 PM
Wheezer61's Avatar
Wheezer61
8th Gear
Carburetor question
I have a '69 F-100 with a 300 c.i. engine. The carb that is on there needs to be replaced or rebuilt. Unfortunately, it's an AutoLine C-814 --- not original. Based on what I've found so far, I'm thinking that a Carter YF would be the one to use. Am I right or wrong? Are there any other suggestions? I'm not looking to have to make a lot of alterations. This is my first Ford truck, so I'm kinda new to all this. Thanks in advance for all your help.
Old Aug 24, 2018 | 05:29 PM
RichS2659's Avatar
RichS2659
That is probably a rebuilder's name and number. It should be an Autolite/Motorcraft 1101 or Carter YF.
Old Aug 24, 2018 | 06:18 PM
Wheezer61's Avatar
Wheezer61
8th Gear
Thanks Rich. After looking at it again, i noticed it said REmanufactured in Canada, not manufactured. I looked but couldn't see any lettering stamped on it. I took a couple if pictures. Maybe someone will know for sure. If it's possible to rebuild, don't want to get the wrong rebuild kit.
Old Aug 24, 2018 | 09:34 PM
RichS2659's Avatar
RichS2659
That is an Autolite/Motorcraft 1101 carb. You can get a carb kit anywhere.
Old Aug 25, 2018 | 05:28 AM
ovalhead72's Avatar
ovalhead72
Personally I'd go with a 300+ cfm Holley I've had bad experiences with remand carbs.
Old Aug 25, 2018 | 05:35 PM
Wheezer61's Avatar
Wheezer61
8th Gear
Thanks for the help Rich, I'll go with that. I watched a video from Mike's Carburetor Parts, and mine looked a lot like the 1100 he was rebuilding. I really appreciate you taking the time to reply.
Old Sep 1, 2018 | 11:46 AM
Lvcrprts's Avatar
Lvcrprts
Don't know if these will help but last one might work for you. Lots of people on here to help you with anything you need. Hmm a lumpy cam for it maybe ?? lol
https://www.summitracing.com/parts/o...view/make/ford
https://www.shop.cliffordperformance...240-300_c3.htm
https://www.summitracing.com/search/...ine-6-cylinder
Carter YFA Carburetor Repair Kit
Paul Massey
Feb 25, 2017 11:01 PM
CelticOne
25
Sep 14, 2015 03:56 AM
Chris 56 f6
19
Aug 18, 2015 07:59 AM
urbex
May 11, 2012 07:07 PM
86 WV_F150
Dec 29, 2009 09:56 PM
