92' 351W with stock heads and 64cc chambers, what would be the difference in static compression ratio going from 64 > 60 and/or 64 > 58cc chambers.
I'm trying to decide between Promaxx with 180cc runners and 60cc chambers or Windsor Jr with 180cc runners and 58cc chambers..
I had a 350SBC in a 4x4 with Dart 180s and it was a torque monster so i am not hesitant to put 180s on my 351.
Upgrading camshaft and want to take advantage of increased duration by increasing static compression to optimize cylinder pressures.
Thanks but the engine is assembled and installed and in running condition, i don't access to those variables but if i did i would have googled compression ratio calculator
Plug in numbers you think are close to what you have. Then change the combustion chamber size to see what effect it has. Closer than a guess from a 3rd party. Serving suggestion.
I did the math(roughly, not knowing the exact numbers) bouncing around going down US287 yesterday (wife driving) and the difference was around a half point on a 351
