compression ratio?
Old Jan 17, 2006 | 12:27 PM
SHUSTANG's Avatar
SHUSTANG
compression ratio?
wondering if amyone knew what the compression ratio of a 96 351w out of an f250 should be. and what the size of the combustion chambers are.
Old Jan 17, 2006 | 04:42 PM
02FordFx4's Avatar
02FordFx4
I am pretty sure that the compression ratio for that engine should be 8.8:1. Someone correct me if I am wrong but I am almost 100% sure that it is.
Old Jan 17, 2006 | 04:45 PM
02FordFx4's Avatar
02FordFx4
What are you asking for in the combustion chamber? The bore of the engine or the displacement in cc or what? If you looking for the bore it is 4.00.
Old Jan 17, 2006 | 05:03 PM
SHUSTANG's Avatar
SHUSTANG
cc of the head combustion chamber. i picked up a 351 roller motor and cant decide to leave the stock pistons in it or use better since ill be rebuildin it. i think ill put different pistons in it if thats all the compression they have. ill be putting it in my mustang with aluminum heads and some other goodies.
Old Jan 17, 2006 | 05:18 PM
MustangGT221's Avatar
MustangGT221
The heads are E7TE's - which are either 64 or 67cc's...somewhere around there. I'm sure you can find it easily through a google search on E7's.
IsoGrifo
Oct 16, 2009 06:37 PM
old75F-100
15
Mar 13, 2006 07:44 AM
amyenns
Feb 13, 2006 09:10 PM
F250SC
Dec 16, 2003 09:38 AM
fordtruckin
Apr 13, 2002 10:12 AM
