Which carpet type for Ranger?
Old Aug 23, 2018 | 08:51 AM
6t6merc's Avatar
6t6merc
I'm looking at carpets at Stock Interiors. They offer "80-20 Loop" and "Nylon Loop". Is either of these close to the material Ford used in '66 trucks?
Eric
Old Aug 23, 2018 | 09:11 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The 80-20 loop is what they used in the Ranger trucks.
Chad
Old Aug 23, 2018 | 09:50 AM
6t6merc's Avatar
6t6merc
Thanks Chad. I might remove the in-cab tank in the future. If I buy the carpet intended for trucks without the tank, can I fold the excess behind the seat?
Eric
Old Aug 23, 2018 | 09:58 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The Rangers originally had 5 separate non-molded carpet pieces - not counting removable floor mats. Some 1965 trucks used a piece of vinyl over the tank instead of the later carpet.
So, if you don't have a tank you could attach the tank carpet piece the way Ford did it and just let it drape down where the tank would have been. Or whatever you think looks good.
Chad
Old Aug 23, 2018 | 10:20 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Eric
To answer this question more directly - with or without the tank a floor carpet should fit the same if it was designed for use with a tank - I would think. But, I suppose that depends on the cut of the carpet, too.
As we used to say in the Army "Terrain dictates"
Most of these replacement carpets look like they would go under the seats and butt up to the "step" that the tank sits on, but not trying to go over that step or underneath the tank. That's why I suspect they would fit the same with or without the tank.
Chad
Old Aug 23, 2018 | 01:41 PM
RangerMercMan's Avatar
RangerMercMan
Are these carpets available in the correct factory colours such as parchment?
Old Aug 23, 2018 | 03:12 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I haven't looked into what Stock Interiors has for these real close yet, but I sent in a request for my truck to SMS Auto Fabrics in Canby, Oregon some time ago - since they only knew U81 and didn't know my truck was special order paint with gold carpets the sample they sent me was the parchment carpet, so I know they have the correct stuff. And they wrote that they have it in other colors, also, as you can see. And with the Mustang seats I won't need any Ford embossing on the seat backs.
I'm planning on just buying enough to make my own from their stock, assuming they have a matching gold for me to use. I can use my originals as a pattern, at least. And there is some parchment edging around some of the sides of the carpet that I'll replicate, too. You can probably see that in my pictures above from earlier.
Chad
Old Aug 23, 2018 | 06:35 PM
RangerMercMan
Thanks Chad. When I get that far I will have to see if they ship to Canada
benderbus
Jan 2, 2017 12:11 PM
Holehawgg
Dec 18, 2011 08:09 PM
donsboy
Jan 24, 2004 09:35 AM
azranger
1983 - 2012 Ranger & B-Series
Oct 11, 2000 11:16 AM
