Manual floor tank selector
Old Jan 1, 2017 | 04:32 PM
benderbus's Avatar
benderbus
Can someone tell me selector positions for each tank? I have tank behind seat and saddle tanks on each side of the bed. I'm sure its not original equipment. 1975 highboy. Appreciate any help. Brian..
Old Jan 1, 2017 | 06:34 PM
Justin73supercamper's Avatar
Justin73supercamper
I just picked up a 73 cab that has a floor selector switch. It doesn't have the behind the seat tank if that will help you I will take a pic and post it in the morning
Old Jan 1, 2017 | 08:26 PM
benderbus's Avatar
benderbus
Thanks
A pic prob wouldn't help much unless it showed what position it points for one of the tanks but thanks
Old Jan 1, 2017 | 08:33 PM
Justin73supercamper
It does have a tag saying what tank is what.It labels main and auxiliary tank.
Old Jan 1, 2017 | 08:48 PM
redcreekauto's Avatar
redcreekauto
My 74 camper special also has the manual floor selector switch. Tag points to either main or auxiliary.
Old Jan 2, 2017 | 11:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No F100/350 of any year came with R & L saddle tanks.
1973/74 F100/350 with factory installed dual fuel tanks:
Manual fuel tank selector valve on the floor adjacent to the drivers side of the seat. The selector switch on the dash changes the fuel gauge from one tank to the other.
1975/79 F100/350 with factory installed dual fuel tanks:
Fuel tank selector valve and solenoid assy. mounted on the frame rail. The selector switch on the dash changes the fuel tanks and the dash fuel gauge from one tank to the other.
Old Jan 2, 2017 | 12:11 PM
JakeHan's Avatar
JakeHan
Not sure what the factory hookup was, but it was basically the same valve as all the "universal" ones you see on ebay and such - they may have had a stop built into the factory one, so you could only use 2 positions, the one and only pickup I ever had with a manual valve had been replaced before I got it, so I'm not 100% sure. If I remember correctly, you have ultimately 4 positions, all the way around the clock, 3 tanks and an "off". If you've got 3 tanks, it's hard to say how it's hooked up, I think the handle can be clocked 2 ways, 180 degrees out, so you might have to unhook lines and blow through it to find out.
Gf2501
Dec 19, 2011 08:01 PM
JoeKramer
May 6, 2011 10:43 PM
*70F250*
Jul 7, 2007 10:41 AM
nuwave
May 12, 2007 03:35 PM
77camperspecial
Aug 20, 2006 01:19 PM
