replaced y pipe
Old Aug 21, 2018 | 10:31 PM
rapidtowing's Avatar
rapidtowing
replaced y pipe
my buddy says its normal for there to be a whistle (its hella annoying and moderately loud, i'm sure other cars can easily hear it) after replacing the pipes but i don't think he's right, so is he?
I've probably gotta tighten some of the exhaust bolts further, right?\
also i'm 99.999% sure it isn't the v-band clamp at either side as they aligned perfectly and were clamped to torque before reattaching pipe bolts
Old Aug 22, 2018 | 07:12 AM
navistarnut's Avatar
navistarnut
If it wasn't loud before all this started, then yes.......you have something not lined up or tight enough.
The 2003 turbo will have more whistle out the tail pipe, but sounds like your problem is under the hood
Old Aug 23, 2018 | 05:17 PM
FL SuperDuty's Avatar
FL SuperDuty
How hard was it to replace your y pipe and who did you go with? OEM , aftermarket?
Old Aug 27, 2018 | 12:41 AM
rapidtowing
was insanely hard for a first timer especially after doing almost every upgrade out there and being just over it .. and having to pull the turbo again.... it was a drain and it wasn't fun at all.. farthest reaching back required from the whole job bar none
Old Aug 27, 2018 | 12:43 AM
rapidtowing
and i went with an aftermarket one off ebay for the cheap with good reviews .. cant complain except for the noise that i believe is coming from elsewhere as the integrity of the baffles looked/looks solid i just gotta tighten some pipes up by the passengers side starter which means i gotta unhook batteries again and havent gotten around to it cuz i been away
Old Sep 6, 2018 | 12:54 AM
rapidtowing
took it to mechanic he said the whistle's coming from the turbo up pipe (the one you all delete that connects to the EGR cooler) ya... can hardly find any for sale.. what gives
Old Sep 6, 2018 | 12:55 AM
rapidtowing
I bought a bulletproof EGR i'd rather not delete it im in california where it may get inspected
Old Sep 6, 2018 | 08:20 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Cheap replacement:
https://www.xtremediesel.com/dorman-...xhaust-up-pipe
Drop that in for the short term fix, then take the old one to a shop and ask them to size and weld in a better bellows.
hosegp
May 30, 2017 11:57 AM
Kdawg89
Oct 11, 2015 08:07 PM
00Dave
Nov 17, 2013 05:29 PM
ROBBINthaHOOD
May 30, 2012 10:32 AM
Aune163rd
29
Apr 23, 2011 01:47 AM
