Hi,
In the optional dash settings for sync 3 trucks, especially XL,XLT, is there a way to see digital readouts of oil pressure, oil temp, etc?
I have found the transmission temp with no problem, but thought that the others might have a digital readout as well, vs the actual gauges.
Thanks
Our 2017 F350 was an XLT Preimum with the 8” center stack and SYNC 3. The instrument cluster included the 4.3”display and six mechanical gauges. I’m not aware of a way to display oil- or coolant temperatures with this configuration.
An an alternative might be to buy an OBD II Adapter and load an OBD app onto your smart phone.
The Lariat + trim levels include an 8” digital instrument cluster that can be programmed using FORscan to,display additional data.
