Testing coolant temp sensor?
Old Aug 29, 2016 | 05:41 PM
Oldanvilyoungsmith's Avatar
Oldanvilyoungsmith
Aight, the coolant temp gauge in the truck doesn't register anything, and my assumption is that it's likely the sensor, but I wanted to see if anyone knew if I could test the sensor with a multimeter to make sure it's bad before I replace it? I checked the continuity and was getting something like 25 ohms if I recall correctly.
(I like to confirm things before replacing, learned my lesson about part throwing before).
Old Aug 29, 2016 | 08:05 PM
pirschwagon's Avatar
pirschwagon
First, check the plug for VREF and see if there is between 4 & 5 vdc. If so, record OHMS on sensor at Room Temp, then immerse in 140*F water and check.
Old Aug 30, 2016 | 06:43 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Not sure what the normal readings are for that sensor as it is only used for the gauge and I have never had an issue with mine. However, they are quite cheap if you suspect it to be bad. Would not break the bank to just replace it.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
homertwo
Jan 23, 2019 08:45 AM
KK560
5.0L Coyote
Nov 3, 2018 09:05 PM
savage250
Feb 1, 2012 10:43 AM
Fordbronco69
Dec 14, 2008 07:10 PM
ShannonM2
13
Jun 3, 2007 09:53 AM
