Boss was saying above - so maybe try to loosen that set screw (someone with a similar one) and see if you can slide the mast and spring up and off. If so, and there is a broken off stub of the original antenna beneath that should answer that question. I know what Boss is referring to.
If I make it back there I will look for sure. Any word on the picture of the rim from above?
The wheel is not a widow maker, which would be the Firestone RH-5° rim
Looks like a Firestone RHP two-piece design. Possibly the 16" x 5" - 5 x 5.5" pattern .620 offset X-40097. Innie nubs. Possibly the 1/2" narrower X-40096.
Basically the 5-lug version of this wheel. It is not banned and can be serviced. Stu can likely confirm.
