Decode VIN paint does not match please help>>
Old Mar 14, 2007 | 07:58 PM
dadstruck's Avatar
dadstruck
Ok gang here is what I have:
F10AK760538
1295M F100 E81 C08
0500 129 4000 53
My dad has owned this truck since day one and it has always had the following from what he and I remmeber:
Interior: Custom cab with the plastic white door trim, red door handles, headliner with the chex pattern, red seat and a black pad dash .
Engine: 240 with a three speed
Exterior: Wimbledon White with what appears as a Poppy Red Ext trim. All red trim fenders etc..are red or poppy red on the inside and out. No repaint or color change at all from what I can see. (see gallery).
Why Does my code show just M for Wimbledon White? am I missing something or better yet what color of red is this thing. Paint is faded hopefully gallery will give you guys an idea. Just about ready for paint and I don't want to put the wrong color of red on the thing.
as usual without this group I would never had made it this far on the project.
thx in advance.
Old Mar 14, 2007 | 08:11 PM
airharley's Avatar
airharley
The only red listed for a 66 is Rangoon Red. The Poppy Red was used on Mustangs and is more orange then red. A friend of mine painted his Mustang Poppy Red and thought the paint shop messed up. You can find paint chip colors to see what Rangoon Red looks like or... The first link is Rangoon and the second is Poppy.
http://www.cobracountry.com/cobra4sa...man-ca-BIG.jpg
http://www.jazzbooks.com/miva/images/car1.jpg
Old Mar 14, 2007 | 09:42 PM
dadstruck's Avatar
dadstruck
Thx for the infor. Looks like its Rangoon Red to me. Matched the color up to the insides of the doors, under dash in cab, firewall, inside of fenders that used to be covered with undercoating ...basically all the factory paint areas and it match to the Rangoon Red.
I'm still confused as to why the paint code M for Wimb White is the only code listed on the VIn. Did Ford just list the base coat code? Only the trim and hood are white sides and inside bed, top of cab is Red.
thx again
Old Mar 17, 2007 | 03:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10 = F100
A = 240 I-6
K = Kansas City Assembly Plant
760538 = 1966
129 = 129" Wheelbase
5 = This is the code for the red, but I have no ref for " 5 " check the code again.
M = Wimbleton White
F100 = F100
E = Red Crush Vinyl / Red Cody Pattern Woven Plastic
81 = 81B Custom Cab
C = Ford 3 Speed Manual All Syncro Transmission
08 = 3.50-1 / Ford 9 Inch Rear Axle / 3300 lb capacity
0500 = 5000 lb GVW
129 HP @ 4000 RPM
53 = Kansas City District
The only paint code listed for F100/350's from 1964 thru 1969 is the letter J. ...which is Rangoon Red. However, Ford used to introduce new colors in the Spring months. So if the code is in fact a 5, you will have to contact a local Automotive Paint Supply Store (where body shops buy paint and supplies)...these places have actual color charts.
Old Mar 17, 2007 | 04:19 PM
NumberDummy
Originally Posted by dadstruck
F10AK760538
129 5M <<< tu toned vehicles have two paint codes. You have listed 5M. There is no 5 code listed in my three Ford paint code sources...see my decode post above.
Old Mar 17, 2007 | 06:22 PM
daveengelson's Avatar
daveengelson
Chip chart for 66 list the exterier colors but to view the Rangoon Red, and Whimbledon White chip need to view the 65 Ford Chip.
http://tcpglobal.com/autocolorlibrar...fordtruck.html
dave
Old Mar 17, 2007 | 06:35 PM
NumberDummy
http://tcpglobal.com/autocolorlibrary/acl_files/fordtruck.html
dave
1964/69 Rangoon Red is color code J. But OP listed a color code = 5...and there is no 5 in the charts you linked to, or the refs I have. He might have a springtime color..Poppy Red? Poppy Red was used in 1967, color code = S. A letter S can resemble the number 5 ...especially on old faded VIN plates.
So if the 5 turns out to be an S = it's Poppy Red, not Rangoon Red which is a J code. All the paint codes listed by Ditzler, Thomas Lacquer Co. or anyone else were originally drawn from info provided by Ford Motor Co., and mistakes were made...especially on springtime colors.
Here is another goof by Ford...the letter Y used to ID a 352 engine in 1966. Only the letter D is listed in Ford parts books, and several decoder charts. But Y is correct for 1966 352's, it was a springtime engine code change! The D was used earlier in 1966 (and all of 1965). Ford isn't perfect!
Old Mar 17, 2007 | 07:27 PM
dadstruck's Avatar
dadstruck
NumberDummy,airharley,daveengelson.... thx a million for the leg work and research on this!!! I just went out and rechecked the VIN and it is definately without any doubt positively a 5. I even used my glasses this time and had my wife verify it. There is no maybe or could be it is definately a stamped 5.
Don't have time tonight but Sunday night or Monday I will put some pictures of the VIN in a Gallery for you. The VIN tag is in excellent shape and very clear. I will also shoot some pictures of the door jams inside doors to give you an idea of the color I'm looking at. This is about to drive me nuts ..one minute it looks like poppy red and the next it looks like rangoon red. Since I'm at the body off frame paint stage I want to make sure I have the correct red. I wonder when this truck was manufactured?
Thx for all your help...you guys are great.
Old Mar 17, 2007 | 08:12 PM
airharley's Avatar
airharley
Oct of 1965 according to your VIN. F10AK760538, 760538 falls between 760000 and 773999 for Oct.
Old Mar 17, 2007 | 08:50 PM
NumberDummy
LOL...well that proves one thing...whatever color it is, it's not a Spring introduction color!
An Automotive Paint Supply Store, by using a computer, can match your color from a sample chip (get it from an area not exposed to the weather, like behind the seat, or on the face of the door, or hinge post).
Old Mar 19, 2007 | 07:56 PM
dadstruck's Avatar
dadstruck
Ok gang this one is getting interesting. Check out the following links regarding paint code 5. It appears that 5 is signal flare red for mustangs. Is it possible my truck has a mustang paint code and red paint of signal flare red. Now for the part that makes this more frustrating ...the more I look at Signal Flare Red the more it matches my truck ........ugh!! but wait..if you look at link number 2 it appears that signal flare red and rangoon red is the same color. What do you all think? Did they type a 5 M on my Vin instead of a J M?
http://www.svs.com/zim/mustang/images/1966-ford-ppg.jpg
http://www.classicmustangshop.com/faqextercol.htm
Old Mar 20, 2007 | 05:24 AM
NumberDummy
Someone who ordered your truck new requested that red color. Ford was accomodating then, and would do things like this.
Caveat: First thing~As the chart states~Colors may be different..depending on your computer screen.
The second link~color code B~Pagoda Green is several times lighter in real life than the picture shows! I had a 64 Galaxie 500XL in Pagoda Green...A yucky color!
Have the automotive paint store match your chip~it can be done.
Old Mar 20, 2007 | 08:27 AM
dadstruck's Avatar
dadstruck
Smile
yep definately going to have chip done at the shop. Thx for the insite .....for some reason this was one of those mysteries that was just driving me nuts. Don't know if my Dad ordered a special color, thats a good thought. Anyway on to the next thing. thx for your help.
I actually found a salvage yard that had 4 of these trucks yest. One had some decent parts, the rest were scrap (no cores) man I felt like my wife and daughters shopping in a shoe store. I was giddy just to find one of these things had a few parts left on them. Are you guys finding these trucks are getting harder to locate. They sure are in my neck of the woods.
have a great day.
76f350spercamprspeal
47
Sep 2, 2018 02:00 PM
Fords & Whalers
Jul 13, 2016 09:33 AM
Mdc9966
Aug 3, 2015 01:20 PM
redstarr1000
Jan 2, 2014 05:27 PM
tod_1
Oct 21, 2000 12:55 PM
