2004 F250 Super Duty 6.0D short bed. Looking at the springs, there is one on the bottom, a stack of 4, then a single flying above that. Is that a factory helper spring? The only other clue I see is that the rear window is a slider. Looks like with Lance's smallest- the 650, I'll exceed the GVWR by 500lbs fully loaded, BTW.
Agree the most obvious indicator would be the rear stabilizer. I doubt you have a camper package if you do not have the stabilizer, although that does not mean you can't add a stabilizer or that you can not haul a truck camper.
Got me a rear sway. Thanks for the info fellas. Can "add" that to my clist posting for selling purposes...as comparison, my l99 2wd SC std bed has no rear swaybar, no rear slider nor the runt leaf setup..
