Sponsored by: Real Truck
No communication with scan tool
Old Aug 17, 2018 | 12:05 PM
Gixxerman1980's Avatar
Gixxerman1980
Hi everyone,
I'm new to the forum. About ten days ago, I was heading to work and my truck unexpectedly died with 9 miles to go. I have a dongle by Automatic that lives in my OBD-II connector. It basically logs my travel and can display basic codes. When my truck died, I had no CEL and my OBD-II dongle was no longer connecting to the ECU. When the truck died, I had power to 12v plugs. Seems like my injectors aren't getting fuel. My first thought was high pressure injector pump, but after having the issue of no OBD-II data transmission, I'm thinking the problem is elsewhere and that the pump is just not being told to work. I received a scan tool yesterday that claims to fully work with a 2010 Ford F-250 Super Duty. Same with it. It gets power, but no data. I looked at all fuses under the hood, and they look good. I have not been able to test relays. I also check fuse #20 inside on passenger side. According to my diagram #20 is supposed to be the Diagnostic connector. As of this morning, my dash is showing the wrench, which wasn't there before. Any ideas?
Old Aug 17, 2018 | 12:40 PM
projectSHO89's Avatar
projectSHO89
Sounds like the PCM isn't getting power. Does the CEL come on when you first turn the key from OFF to RUN?
Old Aug 17, 2018 | 01:22 PM
Gixxerman1980
The CEL does come on as most of the lights do, then after a second or two, all that remains are the seat belt, battery and CEL lights. I haven't tried cranking in a while, but I recall the CEL going away after cranking. Also, I don't hear what sounds like the fuel pump priming like I used to. Oh, when reviewing my log on the Automatic app, it quit tracking my trip at about 4:00 am and I first contacted my supervisor that my truck shut down around 4:30 am.
Old Aug 18, 2018 | 10:45 AM
Gixxerman1980
Well, a guy I'm working with got his little $45 scan tool out and for some reason it was able to connect. The codes I got are U2011, U0115 and B2900.
Old Aug 18, 2018 | 11:24 AM
mgfranz's Avatar
mgfranz
U2011 - Module Transmitted Invalid Data (Non SCP)
This is a generic network code, which means it covers all makes/models, 1996-newer. However, specific troubleshooting steps will vary depending on the vehicle. The generic OBD trouble code U0115 is a serious situation where the signals between the electronic control module (ECM) or the powertrain control module (PCM). Take it in and have the dealer reflash the ECU and/or the PCM.
Old Aug 19, 2018 | 08:36 AM
MrJoeJitsue's Avatar
MrJoeJitsue
I had an issue when every check light came on and the truck was a no start all functions working except the ignition. On another thread someone with the same problem, a poster recommended checking the harness by the E brake ...apparently that bundle connects to the computer , worked for me...my scan tool would not connect either
Last edited by MrJoeJitsue; Aug 19, 2018 at 08:51 AM. Reason: adding link to thread
Old Aug 19, 2018 | 08:55 AM
MrJoeJitsue
cant post the link to the other Thread...
Old Jul 14, 2021 | 04:22 PM
Fordfv's Avatar
Fordfv
Gixxerman1980
What did it end up being? Mine just did the same thing.
Old Jul 14, 2021 | 11:32 PM
Gixxerman1980
Originally Posted by Fordfv
Gixxerman1980
It ended up being my high pressure fuel pump. Hopefully yours is something else. Good luck.
firechief
1997 - 2003 F150
Jan 16, 2011 08:16 AM
pc_2000
Apr 22, 2009 09:20 AM
cjc1
17
Jun 12, 2005 11:22 PM
stacyj
Feb 25, 2004 09:42 AM
DaveW396
Oct 24, 2003 10:25 AM
