Sponsored by: Real Truck
Can this damage be fixed via frame puller ?
Old Jul 10, 2021 | 11:49 PM
Almostconverted666's Avatar
Almostconverted666
Decided to pop the doors open today to take a good look at that dent on my rocker panel and it’s worse than I though. They were smashed and overlapping each other.
I think the top A pillar might be bent in and that’s why the top of the door has such a large gap.
i got tboned 6 months ago and have been fighting the other party with a lawyer , I have bulging discs in my neck at 23 yrs old now with permanent nerve damage.
To make matters worse there’s nothing to go after other than the state minimum which in California is 15k BI and 5K property damage.
the 3rd party insurance is fighting pretty hard not to pay me out despite everything.
anyway enough of that ....... the inner panels and structure of the cab is creased but I have a
buddy at work who knows someone who will fix it for 1500$ with a frame puller
not sure if it’s a viable option or if it will seal enough with new doors if he tries to straighten it out
doesnt look like money’s coming at all unless there’s a long court battle so I can forget about saving for a diesel truck , especially with prices right now in CA
nothing else is wrong with it other than the accident knocked my end link loose and it rattles up against my leaf spring , especially when I turn
someone put the wrong size bushings on too so the sway bar has play
weighing my options
Old Jul 11, 2021 | 06:52 AM
Dweber85rc's Avatar
Dweber85rc
Its hard to see what else may be damaged with just that one picture, but to me your rocker is bent and just needs to be cut out and replaced. A frame puller won't do you any good.
Old Jul 11, 2021 | 07:17 AM
Fefanatic's Avatar
Fefanatic
More than just rocker damage. And yes, a frame machine can get it back to alignment but not cosmetically straight. If you can stand the looks of the rocker once straightened then yes, you can repair it without replacing rocker panel. The floor panel behind the rocker is also damaged and that's where the frame machine would work best to correct. Don't try it yourself, get the professional frame guy to take care of it for you.
Old Jul 11, 2021 | 10:21 AM
super 6.8's Avatar
super 6.8
A shop vac would be pretty beneficial too.
Old Jul 11, 2021 | 07:41 PM
senix's Avatar
senix
they would cut it out and replace from a donor. looks like you need to get it cleaned up and shampooed first.
I would not touch it until it is somewhat clean.
Old Jul 14, 2021 | 07:56 AM
Almostconverted666
that would cost about what ? 10k$ ?
Old Jul 14, 2021 | 11:06 AM
senix's Avatar
senix
hard to say, but expensive yes.
Old Jul 14, 2021 | 04:27 PM
machmedic's Avatar
machmedic
If the A post is bent too they may try to total the truck.
Old Jul 14, 2021 | 07:01 PM
Gyppo Logger's Avatar
Gyppo Logger
Or a leaf blower
Old Jul 15, 2021 | 12:47 AM
madsonp's Avatar
madsonp
Originally Posted by Gyppo Logger
Or a leaf blower
Hey, give him a break, he already cleaned out three bags of garbage out of it.
Old Jul 15, 2021 | 09:02 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I've watched a body shop owner friend of mine fix simular damage by removing the plastic kick plates to inspect any floor or inner panel damage then welding tabs on the rocker panel and pulling it out until it looks close to being back in position, that will also straighten the A piller. Then remove the rocker panel and replace it with new or used. A lot of man hours and it isn't cheap to do.
Demny
Old Jul 15, 2021 | 10:00 AM
redford's Avatar
redford
FTE Leadership Emeritus
At this point a cab swap might be a cheaper option.
flowney
657
Mar 4, 2026 10:39 AM
tjc transport
Sep 27, 2015 05:44 AM
BACAGrizz
Aug 9, 2008 02:27 AM
Dean88
Mar 15, 2008 01:02 PM
matt2491
Jan 12, 2008 10:58 PM
