Went to upgrade my CAI to an S&B and discovered this....
Thanks for the quick reply. Also wanted to note I feel like the truck has lost some low end power after the install (could just be in my head), but when looking at my boost gauge under my TP app on headunit my boost still hits 15.9 psi - 16.2 psi at wot.
Yes for for both parts. Since the S&B already has the "fender hole" the second part is done by default for us.
I did the zoodad mod many, many years ago. I know it didn't hurt anything but I couldn't tell you if it made a whole lot of difference. Yes, colder air from outside has a straighter shot to the filter but it's not like i needed wheelie bars after I cut out 5 square inches (or so) of material.
I also put a screen over the panel section that I cut out to keep larger things from traveling through there to the filter (as well as the intake horn also).
One of these days I might try the secret zoodad mod: https://www.ford-trucks.com/forums/1...out-water.html
Ok we are getting closer haha. So the red line is the one that goes to the air filter reader sensor? Cac boot clamp is? T-clamp bolt? New to diesels and trying to learn all the definitions. What is that mod called as I will look it up? Would def like pictures on what it means to plug the line on the boot.
