Still Having E4OD Problems
Old Aug 16, 2018 | 08:43 AM
neverenoughtools's Avatar
neverenoughtools
Sorry for the really long post.
My transmission is not shifting correctly after the swap. The original thread is
https://www.ford-trucks.com/forums/1...verenoughtools
I swapped in a E4OD in place of a 4R70W. Originally truck was a 1995 RWD and new trans is a 1993 4x4. I used a HOG0 computer and the trans harness from the 1993 donor truck. The transmission harness from the 93 would not plug up to the 1995 without modification. The trans harness has 2 plugs. The big plug was the same on both harnesses but the small plug was different. With only the big plug connected the trans was in limp mode. Because I am NOT an electrical genius and because I was desperate I spliced in the small plug from the 1995 into the 1993 trans harness matching the wire colors. The only problem was The 1995 had 2 more wires than the 1993 so I just didn't connect those. I took the truck for a drive and all seemed to be well, all gears worked. After some more driving I now realize all is not well. All gears function on upshifts and downshifts but I am having some weird issues. It seems that with the O/D on the truck wont shift down into low, or maybe the torque converter is staying locked? I'm not sure which. With O/D light off the truck takes off in low but upshifts are hard and it feels like the truck bogs after an upshift. This seems to me like a TC issue but the truck will idle in gear with my foot on the brake so I know the TC isn't locked at that time. If I cant figure this out I am going to do the manually switched torque converter mod and see if that helps.
Old Aug 16, 2018 | 09:31 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
This is a horrible idea of creating another thread.I would go back to your original and abandon this one.
Old Aug 16, 2018 | 09:56 AM
subford's Avatar
subford
About the two extra wires here a diagram to compare the two transmissions wiring:
Attachment 281592
nick2064
Apr 3, 2017 05:22 PM
swestermann
Jan 19, 2015 10:55 AM
larspetter123
Jun 7, 2014 04:23 PM
zottyzot
Nov 15, 2012 12:40 PM
jdwoody
Mar 19, 2011 01:57 PM
