Sponsored by: Real Truck
OBDII "N/A" Error Code
Old Aug 14, 2018 | 06:20 PM
mgfranz's Avatar
mgfranz
So twice in the past month my 2003 F250 V10 Super Cab has thrown a CEL that my OBDII reader returns a "N/A" error. I use this reader for all my vehicles and it has never failed to provide a proper code before. I even checked it's functional ability by inducing an error on one of my other vehicles and it is working fine.
So, what would cause a CEL that returns a "N/A" error?
Old Aug 14, 2018 | 10:28 PM
Fefanatic's Avatar
Fefanatic
Sometimes it's not a engine code that turns the cel light on. It could be a transmission, pcm, or other error your reader isn't capable of reading. Most cheap readers just read common codes and don't get too deep into the systems. Have you tried FORSCAN?
Old Aug 15, 2018 | 11:22 AM
alloro's Avatar
alloro
Make sure the fuse for the 12v lighter socket is not blown. It's the same circuit that powers the OBD-II port.
Old Aug 15, 2018 | 09:46 PM
mgfranz's Avatar
mgfranz
Which lighter socket? I have 2. I use the regular socket everyday so I doubt that is the problem,
Never heard of Forscan, interesting thought,,, I own both VWAG and BMW vehicles, both of which support laptop software for diags so this might be a viable option. Just gotta make sure to get the right cable. Lots of $20-30 cables on eBay.
Old Sep 22, 2018 | 06:53 PM
mgfranz's Avatar
mgfranz
OK, so I purchased the necessary cable and installed Forscan, it threw a P0457 EVAP code. I doubt it's the gas cap since it's relatively new, though I DO suspect it to be the fuel pump gasket on the tank. I changed the pump about a year ago and I have suspicions on how tight I got the pump on the tank. I guess it's time to pop the bed again...
Is the Evap canister a wear item? Should it be changed in it's lifetime?
traxx808
May 2, 2011 07:30 AM
fdaugher
Nov 27, 2010 07:02 PM
5.4L to Freedom
Apr 13, 2010 10:42 AM
Johnny Bravo 45
Jan 8, 2010 10:53 AM
Road Hog
Electrical Systems/Wiring
Apr 13, 2007 07:48 PM
