Sponsored by: Real Truck
OBD2 Questions
Old Apr 12, 2010 | 05:30 PM
5.4L to Freedom's Avatar
5.4L to Freedom
OBD2 Questions
So I've been having lots of issues with the truck lately, and it hasn't thrown a code. So naturally, I verified the check engine lightbulb is not burned out. On the OBD2 port there is voltage,
But get this, because I dont trust that stupid light... I started unplugging and playing. Here's what I have found:
Disconnected cam sensor: runs and drives exactly the same, no check engine light
Disconnected MAF: barely runs, still no code
Disconnected various coils: barely runs, still no code
Is there anything I can do to make it throw a code? How do I go about troubleshooting something like this? All the repair material I've read is dependant upon codes, and well, without them I can't do too much
Old Apr 13, 2010 | 02:20 AM
5.4L to Freedom
So after doing some research, it turns out on GM vehicles the CEL can be deactivated and certain categories of codes/ all codes can be ignored if that is how the tuner set them up.
Does anyone know if this can be done on a Ford, or if anyone has had experience doing it?
I checked the pinout of my OBD2 (with the Fluke) port and everything is live and working, but for some reason the PCM isn't acknowledging anything that should throw a code~ I'm wondering if perhaps the dealer that sold me the truck deactivated the CEL... it turns out everything else they told me about the truck was a lie.
On the plus side, in the search for my PCM I found receipts behind the glovebox, turns out the truck spent at least a year or two in Miami Gardens.
Old Apr 13, 2010 | 10:42 AM
GlamisDude's Avatar
GlamisDude
I have found that it takes two faults of the same problem in two different run cycles. So to get your code to show, make the problem then shut it off and restart. code should come up.
89BlackBeauty
41
Apr 4, 2009 01:07 PM
Tomget
1983 - 2012 Ranger & B-Series
Sep 18, 2008 11:26 AM
Xdrive
Feb 10, 2007 05:58 PM
justbabs
Nov 21, 2004 11:06 AM
69crewcab
25
Sep 9, 2004 10:31 AM
