Rebuild 2000 V-10
Well, good for them. I appriciate their honestly as should you.
It is no different than a 5.4 or 4.6 though. The torque plate needed to correctly bore and hone would be their biggest expense.
I would suggest other routes though.
1. Buy a new block from Ford as it will cost about the same as machining the old block and will have a std bore. Then install new pistons and reuse the forged crank. I would also replace rods....they can weaken over time.
2. Buy a new shortblock from Ford. It will come with new pistons, crank, and rods, all assembled. No refurbished parts at all.
3. If it's a 2V motor buy a new motor from ford. It will come sealed with all new parts from heads down. You will need your used intake and stuff. It's about $4800 plus core. You néed to order a 2008 and up E350 van V10. Swap out oil pan and you have a brand new motor.....not refurbished.
Here is the part number for the short block.
2C3Z-6009-BA
$1795.
I don't think I could get a block machined, have a new oil pump, crank,pistons,rods and bearings assembled for $1795 unless labor was free. even than is close.
So figure 40 to 60 man hours, but I removed the bumper grill, radiator,ac condenser, inner support, and etc. Made the pull and replace easier for a 1 man operation.
$2000 should be a fair price for labor.
