Rear axle fluid change question
Old 08-12-2018, 08:24 AM
smlford's Avatar
smlford
smlford is offline
I'm coming up on my 150K service and according to my maintenance manual I'm going to change my rear axle fluid. The specs call for 80W-90 fluid. I like using Mobil 1 products when I can and Mobil makes a 75W-90 gear lube.
will this be OK?
Thanks!
Old 08-15-2018, 01:22 PM
smlford's Avatar
smlford
smlford is offline
Anyone help??
Old 08-15-2018, 02:51 PM
CBB9M's Avatar
CBB9M
CBB9M is offline
IMO, here are your options:
a) Use what the manufacturer specs for the gearbox (what I'd do if it were mine).
b) Deviate and use what you're proposing.
Firm answers to b) will kick up up answers (personal opinions) that sorta fall in the category of politics, religion, evolution VS creation, global warming is caused by people VS global warming is a natural event caused by nature. You get the idea.
Old 08-16-2018, 10:15 AM
reddog99's Avatar
reddog99
reddog99 is offline
The 75W-90 will be fine. I've been running the Mobil synthetic gear oils for years with full satisfaction. If you have a limited-slip, then remember to add the "friction modifier" recommended by Ford.
Old 08-17-2018, 11:52 PM
7622RM's Avatar
7622RM
7622RM is offline
If the gear oil you want to use meets all other requirements, I wouldn't even think twice about using a multi-weight gear oil that's 5 points lower on the bottom side, especially if it's synthetic. You'll start out with a gear oil with characteristics of a 75-weight oil only when it's cold outside. As it heats up and the viscosity modifier molecules start to unfurl, you'll get a gear oil with characteristics of up to a 90-weight oil.
My 1997 owner's manual specifies "Thermally stable rear axle lubricant, 80W90. Ford Part Number XY-80W90-QL, Ford Specification WSP-M2C197-A. Add 4 oz. of Friction Modifier EST-M2C118-A (Ford Part No. C8AZ-19B546-A) for a complete refill of Ford Traction-Lok Rear Axles."
I use Mobil 1 synthetic 75W-90 either with the GL-4 or GL-5 specification.
Old 08-18-2018, 07:26 AM
ArmamentDawg's Avatar
ArmamentDawg
ArmamentDawg is offline
How do I know what type of axle I have in the rear of my 1998 Ranger 2WD XLT?
Old 08-18-2018, 09:44 AM
Rockledge's Avatar
Rockledge
Rockledge is offline
You'll find the axle code on the "Vehicle Certification Label" which is the sticker on the driver's side door.
  • 84 — 3.45 non-limited slip (Ranger)
  • 86 — 3.73 non-limited slip (Ranger)
  • 87 — 4.10 non-limited slip (Ranger)
  • 89 — 4.56 non-limited slip (Ranger)
  • F6 — 3.73 limited slip (Ranger)
  • F7 — 4.10 limited slip (Ranger)
  • 92 — 3.08 non-limited slip (Ranger)
  • R5 — 3.55 limited slip (Ranger)
  • 91 — 3.27 non-limited slip (Ranger)
  • 96 — 3.73 non-limited slip (Ranger)
  • R6 — 3.73 limited slip (Ranger)
Old 08-19-2018, 08:09 AM
ArmamentDawg
Awesome so mine was coded "86" so I have the 3.73, non-limited slip rear end.
Old 10-25-2018, 07:09 AM
SFCJones's Avatar
SFCJones
SFCJones is offline
I looked mine and it is coded R7. I know it is a 4.10 but I am not sure what the other specs are. Mine is making a roaring noise and have found some metal in it. I guess it is time to look at the ring and pinion gears and make a decision on whether to sell it or keep it.
Old 10-26-2018, 09:39 AM
Dhagerty40's Avatar
Dhagerty40
Dhagerty40 is offline
mine is also an R7. it is a 4.10 limited slip gear box and 8.8" gears.
Old 10-26-2018, 04:44 PM
SFCJones's Avatar
SFCJones
SFCJones is offline
How did you determine 8.8 gears?
Old 10-26-2018, 06:35 PM
Dhagerty40's Avatar
Dhagerty40
it is by the chart 8.8 axle.
from this chart: https://www.therangerstation.com/tech_library/axle_codes.shtml
Old 10-27-2018, 06:26 AM
SFCJones's Avatar
SFCJones
SFCJones is offline
Thanks, Hopefully I have enough information to get the parts I need to get the rear end rebuilt.
coreyallan01
01-11-2014 11:55 PM
makthenif
1997-2006 Expedition & Navigator
06-10-2011 03:42 PM
aceltx09
1999 to 2016 Super Duty
09-12-2010 08:03 PM
tomucen
Aerostar
11-06-2005 10:42 AM
MyBlueCrew
06-03-2004 10:36 PM
Quick Reply: Rear axle fluid change question
