Fluid Specs for Rear Axle
Old Jun 2, 2004 | 02:36 PM
MyBlueCrew's Avatar
MyBlueCrew
Having the shudder action going on. Going to change the fluid in the rear end needing to know what type of fluid to use. I know I have to use Frictin mod.
Thanks,
Scott
Old Jun 2, 2004 | 05:36 PM
gkbid's Avatar
gkbid
Hi Scott,
According to my book...
97-02 Expy Differential Lubricant:
Front - Use SAE 75W-90 GL-5 gear lubricant
Rear - Use SAE 75W-140 GL-5 synthetic gear lubricant* **
* Add 4 oz. of friction modifier to 8.8" andd 9.75" inch rear axles, or
** Add 8 oz. of friction modifier to 10.25" rear axles w/lube change.
Hope this helps,
Gary
Old Jun 2, 2004 | 08:25 PM
Matt03Expy's Avatar
Matt03Expy
Put The Friction Modifier In First!!
Old Jun 2, 2004 | 09:21 PM
MyBlueCrew's Avatar
MyBlueCrew
Thumbs up
Thank guys for the responses... Has anybody done this job if so once the rear axle is put back on is there a plug to fill it up or do go through the breather cap like on the 8.8 mustang?
Old Jun 3, 2004 | 04:17 PM
gkbid's Avatar
gkbid
You should have a filler plug, use a 3/8" ratchet or breaker bar to remove - use your finger as a "dipstick" to check the level. (Be sure to drive the vehicle first to warm the fluid so it will drain more easily and completely).
Old Jun 3, 2004 | 10:36 PM
rangedog's Avatar
rangedog
There are two different friction modifiers, one for synthetic and one for non-synthetic.
Dolmar9010
Apr 7, 2010 08:08 PM
scott0531
Sep 20, 2009 01:23 AM
Scott Word
Jul 28, 2003 07:37 PM
capt scott
Jan 28, 2002 05:41 PM
