Do the 15-16's have CAC failures
Old 08-08-2018, 03:29 PM
rocco7869's Avatar
rocco7869
rocco7869 is offline
Is this a problem on the 15-16 models or just the 11-14? Just need to know if I need to be prepared. I had CAC issues on my 06 blowing the hose off when towing and I don't want to do side of the road repairs on my 16.
Old 08-08-2018, 03:37 PM
Deuce40s's Avatar
Deuce40s
Deuce40s is offline
Yes, all models. Also it is a problem (will be a problem) for 17s and 18s. I haven't upgraded mine yet but I plan on it.
Old 08-08-2018, 03:58 PM
The Bone's Avatar
The Bone
The Bone is offline
I have 60,000 on mine and I see no problem with mine. I tow all the time. 30,000 miles so far 34' 5th wheel
Old 08-08-2018, 04:59 PM
senix's Avatar
senix
senix is offline
Received 1,429 Likes on 1,022 Posts
Mine has been fine, but I do have a backup just in case.
Old 08-09-2018, 10:03 AM
MKrenn's Avatar
MKrenn
MKrenn is offline
I've only had this truck for a couple months. My son works at a local diesel shop and looked it over when I got it. He told me it's about to fail. I carried a band clamp with me just in case. Dealer replaced it free of charge under factory warranty. It has 44,000 miles on it. It's a good idea to just replace if you see signs. Ford usually covers it. It's no fun to be hooked up to a camper and blow one. I have seen that!
Old 08-09-2018, 07:18 PM
SkiSmuggs's Avatar
SkiSmuggs
SkiSmuggs is offline
Folks have reported failures in the upper 20s while some make it over 100K without. I installed the Rudy's upgrade to avoid the issue. Even the latest models still have the same cheap hose that has been failing since the 2011 model year.
Old 08-11-2018, 09:25 PM
Overkill2's Avatar
Overkill2
Overkill2 is online now
Making donuts deplorable
Received 6,443 Likes on 4,692 Posts
x2 like SkiSmuggs. I installed the Rudy's kit as well for insurance. Didn't want to wait for the failure on the side of the road.
Old 08-15-2018, 10:37 PM
rocco7869's Avatar
rocco7869
Bought the Rudy's kit today. I'll probably keep the stock setup in the truck just in case something goes wrong.
Old 08-16-2018, 02:34 PM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
6.7 Weight Loss
Tick Tick Tick Tick - Seriously though, some people never have an issue. The "if it weren't for bad luck I would have none at all" applies to me so I wasn't going to take the chance of being dead on the side of the road with my thunderbird in my trailer.
Old 08-16-2018, 04:32 PM
Braggs's Avatar
Braggs
Braggs is offline
I've got 80,000 miles on my 2015 without any issue. I wonder how many of these blowouts were caused by excess boost pressure from tunes and other such modifications. I know one of the things they love to do is remove the boost limiter so they can get over 25lb of boost. I've never seen mine go above that level being stock all the way.
Old 08-16-2018, 05:17 PM
rocco7869's Avatar
rocco7869
Well as far as I know, mine is completely stock but I would rather have the assurance than to be forced to change it on the side of the highway. These don't boost as much as my 6.0 did but the factors add up with temps and pressure and plastic parts so I'll ere on the side of safety. My 6.0 didn't have some of the issues that others were plagued with but I proactively corrected things anyway. Maybe that's why, maybe not. Who knows.
Old 08-16-2018, 09:46 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
Mine was completely stock when it blew, So was Rodney's.
Old 08-16-2018, 10:54 PM
Bohen's Avatar
Bohen
Bohen is offline
Is this the only piping that is known for failure ?
Old 08-16-2018, 11:22 PM
kper05's Avatar
kper05
kper05 is offline
Mine was stock 400 HP, 21 PSI max, stock air filter, etc.. It didn't burst open like most (must have noticed it in time) but was cracked at both ends, down on boost at 96,000 miles and I could hear the leak.
Old 08-17-2018, 04:24 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Yes, the cold side is the problem, The hot side is metal. There has been one case on this forum that I am aware about where the boot was bad/blown.
Quick Reply: Do the 15-16's have CAC failures
