Kinda weird electrical issue
Old Aug 7, 2018 | 08:28 PM
mikezayed's Avatar
mikezayed
Hey all. I'm hoping someone can help me with this. A contractor has asked me to check out his 2006 E250 econoline van. He is having a weird issue, and I have searched and haven't came across any info that maybe useful. Here is what he told me (I have not started digging into the van but also dont want to start chasing my tail around for days without a idea where to start). This is a electrical issue. About 6 months ago he had his engine replaced with a super low mileage motor. Everything went fine with the replacement, except when he took the van back his issues are as follows: when he has his left turn signal on, and presses the brake it stops flashing but will work fine without the brake depressed. Also he has no parking lights. It almost sounds like a MFS but before I go and throw parts at it I want to get some opinions. Brake lights work as they should. Could it be in relation to maybe a missed ground on reinstall of the engine? Could a ground have been damaged? I'm not sure if he has a trailer connector but I'm gonna check that as a lot of people say a few issues could revolve around that. Any other issues?? Any and all help is greatly appreciated. Thank you! Feel free to ask questions too and I'll try my best to answer them. Thanks again!!!!
Old Aug 9, 2018 | 07:37 AM
maltondhc's Avatar
maltondhc
When the left brake light stops working what does the front light do? Also, when the signals are activated, in both directions, are they equally bright on both sides, or is one side a bit dimmer? Do the running lights also faintly blink in unison? You will have to look close for that one, better at night when dark. You say the running lights don,t work, all this seem to point that the wiring harness for the front parking/turn lights harness could have been damaged during the engine swap., Really check the right side carefully
Old Aug 9, 2018 | 06:49 PM
wirelessengineer's Avatar
wirelessengineer
Is there any particular reason you started a new thread?
https://www.ford-trucks.com/forums/1...cal-issue.html
mikezayed
Aug 8, 2018 09:56 PM
hollygreenf250
Jun 25, 2018 06:42 PM
1/2 Ton
Nov 24, 2012 08:39 AM
sleep_deprived129
Mar 17, 2009 01:38 AM
VikingBabe
Electrical Systems/Wiring
Jun 2, 2005 02:28 AM
