E-350 brake light not working
Old Nov 23, 2012 | 09:35 PM
1/2 Ton's Avatar
1/2 Ton
Howdy ford fans.
Here's the scoop. 2006 E-350 15 pass. van brake lights not working. New pedal switch, fuses good, turn, hazards, and parking working fine. But all 3 of the brake lamps don't work. Any ideas?
Old Nov 23, 2012 | 10:18 PM
dlibson's Avatar
dlibson
Gotta be a wiring problem between the switch and lights. Trace to wire back and look for a break.
Old Nov 23, 2012 | 10:40 PM
Yahiko's Avatar
Yahiko
Had any other work done to it? Check the ground for the lamps with you handy DMM.
Also check the socket and see if you have power. Most likely something got unplugged
some where. Good place to start is down under the dash and look to see if there is
an open connector.
Sean
Old Nov 24, 2012 | 08:39 AM
1/2 Ton's Avatar
1/2 Ton
No work done by me. We had the plugs done prior to purchase. We've owned it for 2 - 2 1/2 months. We towed a utility trailer with it, and the lights stopped working a short time later. I will start with connections. Are there any under the dog house?
mattific
Jul 19, 2018 06:33 AM
Fzcruzer
May 1, 2014 07:05 PM
1/2 Ton
Nov 25, 2012 01:22 AM
SilveradoCA
Jul 16, 2010 10:03 AM
RangerPilot
General Automotive Discussion
May 27, 2006 05:30 PM
