Headlights Depot
Old Aug 6, 2018 | 04:45 PM
Jeff53's Avatar
Jeff53
Headlights Depot
I was looking at these headlights on Amazon:
Headlights Depot Black Halogen Headlights Depot Black Halogen
. I was wondering if anyone has used these and what the opinions were on them. I'd like the look of the Harley lights on my black Ex, but I don't want to deal with swapping out the header panel or cutting my current one to install them. I don't have any plans to upgrade to brighter lights or LEDs and this seemed like an easy alternative to get a similar look. But, I don't want to get them if they're crappy quality.
Old Aug 6, 2018 | 09:55 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I got mine from Tony at 1A Auto. Excellent customer service! Once if the lights sprang a leak and fogged up, they quickly sent out a replacement set without question.
Old Aug 7, 2018 | 06:35 AM
Jeff53's Avatar
Jeff53
I just took a look at them
They seem to offer only the stock replacements. I was looking for the black look of the Harley lights. I didn't see anything similar on their website the to ones I linked. Thanks for the suggestion, though. I didn't think to look there initially.
Old Aug 7, 2018 | 08:24 AM
Matt M, PA's Avatar
Matt M, PA
I can't comment either way...except when I looked at the link, one of the pictures a reviewer placed makes it look like the lights on Amazon don't fit very well. Here's a screenshot of the pic. Perhaps there's something else going on?
Old Aug 7, 2018 | 09:11 AM
Toreador_Diesel
that's where I got my Harley lights for my '05
Old Aug 7, 2018 | 09:34 AM
ShelbyHauler's Avatar
ShelbyHauler
From the What did you do to the X today? thread...
Originally Posted by Kai Herrmann
Got some new headlights in, LED designed projectors with RGB internal lights and of course the new style running light.
Running lights on:
DRL's.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
"Designed to fit
1999-2004 Ford F-250 F-350 Superduty
2000-2004 Ford Excursion
NOT Compatible with Sealed Beam Headlight Models
Some Model Requires Modification To The Brackets with Perfect Fitment
Product Feature
Infinity Black Edition
Crystal Clear Lens Matched with a Matte Black Housing.
100% Brand New Headlight Assembly in Box
Both Driver Side & Passenger Side Included.
F'King Bright Series Halo
The Absolute Brightest Halos on the Market. Rated at 5000K Color Temperature.
Wiring For OLED Tube Required
You Need to Wire the Power(+) and Ground(-) Wires of OLED Tube to Any Power Source You Prefer In Order to Function.
German-Made Projectors
Our Low Beam uses quality glass lens to provide brighter illumination with a crisp cut-off line.
Triple Layer Protection
Triple-Layered Coating That Combats The Debris, UV Rays, And Weather Your Vehicle Faces Every Day.
100% Street Legal, SAE DOT Approved
US Department of Transportation and Society of Automotive Engineers Certified Products. Our Products Meet all Regulation Standards in USA & Canada.
so far I'm pretty happy with them. Cutoff looks good and light dispersion is nice. I"ll get some pics of that when I get time this weekend.
I'm looking forward to hearing more about
these these
VIPMOTOZ Rainbow ($318.01 & FREE Shipping) that Kai Herrmann got. I looked on Amazon and found these that look the same, but do not have the color changing ability. But for the extra $10, why not get the VIPMOTOZ rainbow lights?
Spyder Ford F250 Super Duty 99-04 / Ford Excursion 00-04 1PC Light Bar Projector Headlights With Black Housing And Clear Lens for $308.87 & FREE Shipping Spyder Ford F250 Super Duty 99-04 / Ford Excursion 00-04 1PC Light Bar Projector Headlights With Black Housing And Clear Lens for $308.87 & FREE Shipping
Lastly, on Amazon, I found these
For 99-04 Ford F250 F350 F450 F550 SuperDuty Pickup LED Tube Bar Black Projector Headlights Pair LH+RH For 99-04 Ford F250 F350 F450 F550 SuperDuty Pickup LED Tube Bar Black Projector Headlights Pair LH+RH
for $265.99 & FREE Shipping
I'm only posting these others as they have the same "LOOK", Light Bar Projector Headlights With Black Housing And Clear Lens, but can not say much about the quality due to lacking reviews. The VIPMOTOZ Rainbow lights have the best description and also state " Low Beam uses quality glass lens". I can only assume the others are all plastic? NONE of the three show the side and none are installed. So, Kai Herrmann, we are waiting to hear back from you with more pictures!
Old Aug 7, 2018 | 10:12 AM
Jeff53's Avatar
Jeff53
Harleys
Mine is an 04. I don't want to replace the header or cut mine
Old Aug 7, 2018 | 10:19 AM
ShelbyHauler
I'd be OK with a little trimming, but not the big cutout required to put the 05 lights in.
Old Aug 8, 2018 | 04:57 PM
robert_l_ross's Avatar
robert_l_ross
I did the 05 lights and while there was a lot of removal to get the new lights to fit...the quality of the reflectors on the 05 lights made it MORE than worth the while. I purchased the 'clear' lense replacements from Amazon twice (different vendors) and they either fogged up within a few months, or started to sun-fade.
Add to that, the reflectors weren't any better than stock.
I finally dropped the $ and got the 05 single-housing light (headlight plus turn signal and side marker) and the reflectors are light years better.
Again, it did suck to have to cut the clip, but it only took maybe 15 minutes per side with a Dremel to get it cut and smoothed out (wear a mask when you do this, people!)...and it was maybe the single best mod I've done after the V/Modded B spring swap...the reflectors on these are just amazing.
Old Aug 9, 2018 | 03:26 PM
ShelbyHauler
Ok, I know this has been discussed NUMEROUS times, so let me ask again, here. Will these 05 lights fit on a 00-04 with the header panel cut out as indicated even though the 05 has a deeper grill? Trying to make a decision here and I like the description and the supposed use of GLASS on the 05 ones Kai Herrmann used vs the others that are said to fit the 00-04 (still with trimming)?
VIPMOTOZ OLED Neon Tube Black Projector Headlight Lamp Assembly For 1999-2004 Ford Superduty F-250 F-350 Pickup Truck & Excursion, Built-In Rainbow RGB LED Low Beam, Driver & Passenger Side VIPMOTOZ OLED Neon Tube Black Projector Headlight Lamp Assembly For 1999-2004 Ford Superduty F-250 F-350 Pickup Truck & Excursion, Built-In Rainbow RGB LED Low Beam, Driver & Passenger Side
$318.01 (note, they say 1999-2004, is that correct? Amazon states they will not fit my 2004 EX)
vs
$265.99 (Amazon states these WILL fit my 2004)
Above are "Projectors", but robert_l_ross used the single piece 05 "Reflector" type. I do understand the LED ones are the ones to currently stay away from due to poor light pattern.
Splash67
Jul 7, 2013 11:25 PM
Nolefanlt
Apr 24, 2012 01:08 PM
J1nx93
17
Apr 16, 2010 03:37 AM
Kirbys73F100
1983 - 2012 Ranger & B-Series
Feb 2, 2010 09:45 AM
92merc
1997 - 2003 F150
Dec 19, 2005 08:44 AM
