replacing 3 speed with automatic steering column?
Cut floor hump?
Appreciate the info, did you do it yourself? reason I ask is I'm wondering if I will need to cut the floor hump. I do not want to cut on the truck I want to be able to return it to original when my son is done with it...
THanks
THanks
Hey I was just looking at the LMC website and they are showing a blow up of the steering components and it looks like I can replace simple things in the column and use the existing column, what do you guys think (I put link below)?
Truck Parts and Truck Accessories
Again, I can't advise on whether your existing column can be modified for auto shift.
If you mean do you have to cut the hump to swap the transmissions,the challenge there is the cross member that runs across under the transmission. It will not provide sufficient room to get the c4 between the floor and the cross member. It can be removed by grinding off the rivets. At least that's what I did.
g84t8f1
01-16-2009 05:24 PM
zoomeroo
04-06-2007 02:06 PM
