Weird electrical issue
Old Jun 17, 2024 | 03:38 PM
Sir Dam I hate this hot tr's Avatar
1st Gear
Need help
Originally Posted by xcrsp440
I’ve read that those symptoms can occur when the instrument cluster is going bad. Research a company called circuit board medics. They rebuilt ours.
Does the alternator work when this is occurring?
e-cluster-repair/ This video demonstrates how to remove the instrument cluster from a 2005 - 2007 Ford Super Duty vehicle. The Super Duty instrument cluster has several common issues, with the individual gauges and with the battery saver relay. Some common problems are: Speedometer or other gauges sticking or giving incorrect readings, intermittent power to radio, power windows, or interior dome light, intermittent power to all gauges, or low fuel indicator is on constantly. Replacing the instrument panel is not the best solution, because the F-250, F-350, F-450, & F-550 replacement instrument clusters use the same faulty components as the original cluster. We will repair your cluster, replacing not only the faulty components, but also rebuilding ALL of the gauges and relays with upgraded components to ensure proper functionality.
will you reach out to me with an email have a question?
Old Jun 17, 2024 | 04:09 PM
bismic's Avatar
bismic
How often does that work?
Old Jun 17, 2024 | 04:50 PM
BLADE35's Avatar
BLADE35
Interesting for sure
Sam A
16
Jun 8, 2020 05:41 PM
lanneinbc
Oct 18, 2018 08:14 PM
pancake
Electrical Systems/Wiring
Jun 8, 2016 01:23 AM
tsgs
Oct 23, 2010 11:18 PM
sunt5
Oct 30, 2008 11:08 AM
