What size tip for borescope/endoscope?
Old Aug 4, 2018 | 08:47 AM
navistarnut's Avatar
navistarnut
As the question states.
Want something that I can get in the injector tip hope to inspect things.
(This may or may not be related to an 04 project truck that the my boy and his friend bought last night. Has #6 contribution code and smokes like a train, wet EGR valve, cam position sensor code..........)
Good thing they start tech school in a few weeks
Old Aug 4, 2018 | 09:36 AM
TooManyToys.'s Avatar
TooManyToys.
You need under 7mm.
I had a Snap-On Borescope with the stock 8.5mm imager but also had the 5.5mm imager to get through the injector hole.
I shouldn't have sold that off........
Editing in......
I bought a wifi borescope for my iPhone that works quite well. At the time all of the cameras seemed to be in the 8mm range, but I just looked at Amazon and there are now 5.3mm (2.1") units out there. It may be a good alternative.
Old Aug 4, 2018 | 11:48 AM
navistarnut
Jack, much appreciated.
I was hoping Amazon or similar had something a little cheaper. If I was wrenching for a living I would invest is a name brand, but since I am too picky and would starve on flat rate......I'll keep the day job and do this on the side
Old Aug 4, 2018 | 11:57 AM
TooManyToys.
The Snap-On I had tends to trade at about $400 on eBay, around where I sold mine years ago.
This is the newer, smaller version that I have in my wish list.
https://www.amazon.com/gp/product/B079KY64Z9?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=BQV0PJ60GA3NHT847TRM https://www.amazon.com/gp/product/B079KY64Z9?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=BQV0PJ60GA3NHT847TRM
Old Aug 4, 2018 | 11:04 PM
mattdoc88's Avatar
mattdoc88
Amazon Amazon
I have this one and bought it specifically to look into a cylinder through the injector hole and it worked.
Look down at post #18 from my thread here, and I show a pic of my piston thru the hole. As I note there, it's a LOT easier to see what's going on while you're watching the live video on your phone/laptop. The screenshots end up a bit blurry. I could clearly see a ring coming through the top of a piston, so I knew it was engine-pull time.
https://www.ford-trucks.com/forums/1...e-knock-2.html
Old Aug 5, 2018 | 03:16 AM
navistarnut
Appreciate the feed back, I did end up ordering one yesterday.
It was a limited time lightning deal for 31 bucks
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
It's similar to both of those you guys linked for me. I had forgot about that post mattdoc. Certainly hope I don't find what you did.
Truck was bought pretty cheap, but it won't be if I see what you did!
As far as I know it wasn't driven that way long. It's a one owner, bone stock.
I might start a thread on it once we get things going, just for kicks
Old Aug 5, 2018 | 07:47 AM
TooManyToys.
I keep forgetting about that Mattdoc88, sorry.
That was a good deal.
Old Aug 10, 2018 | 04:06 PM
navistarnut
Endoscope worked quite nicely. #6 cylinder looked just fine.
I will say those boys dodged a rather large bullet. Upon further inspection of the injector tip, noticed a crack from one side to the other, top to bottom....minus the top 1/16 or so.
Needless to say it would not have ran much longer without some serious damage.
Turbo is shot(I'm sure that is where some of the smoke was coming from....a ton of shaft play), and to top it off the back bolt won't come out. I've never fought that bolt on the later style since it's easy to get on.
I have a feeling they didn't get the socket squared good enough the first time, and didn't let it soak overnight either.
I've tried everything but a die grinder with a cut off wheel. I have one that will just fit back there.......will see how that goes.
Old Aug 10, 2018 | 05:29 PM
TooManyToys.
I have a long 1/4" ratchet that I've used along with a pry bar I believe off the firewall to get enough force to break the bolt/collar loose. Not sure a die grinder will help with this situation due to the shaft through the pedestal. Some have unbolted the pedestal.
I thing DTR showed in a video the leverage trick.
Guess I'll be ordering that scope......
Old Aug 10, 2018 | 05:35 PM
TooManyToys.
OK, he does it different, but whatever works. 2:20 into the vid it's discussed.
Old Aug 10, 2018 | 05:39 PM
TooManyToys.
Better video
Old Aug 10, 2018 | 11:05 PM
navistarnut
The small 90* air grinder with a cut off wheel worked like a charm. Took some finesse with the air hose since it's so snug but it just fit.
Since it's the later style where you can see what you are doing it made things easier.
Boy is that down pipe a mess of caked on oil, I'm sure it will take some time to burn that off.
Old Aug 11, 2018 | 06:39 AM
TooManyToys.
Glad you got it.
Errols
Aug 27, 2017 06:22 AM
drdrzr
Apr 16, 2014 12:18 PM
purplewg
Apr 1, 2013 08:09 AM
icanfixthat
1978 - 1996 Big Bronco
20
Jan 3, 2007 08:46 AM
ksubuck
May 7, 2006 07:00 PM
