Stall after start
Old Aug 23, 2017 | 09:11 PM
Errols's Avatar
Errols
Stall after start
Hello everyone.
This is my first post her because i have had literally no issues with my 2004 F250 Super Duty.
Went out and started the truck like every other time for the past 13 years. Started backing out of the driveway and burped the throttle and it just quit??
I put back into park and it rolled over for about a minute and finally caught.
When i put it back into gear i had zero throttle response.
I have a NOx sensor fault code and and EGR fault code.
I replaced the FICM 2 years ago.
Old Aug 23, 2017 | 09:37 PM
navistarnut's Avatar
navistarnut
Originally Posted by Errols
Hello everyone.
Do you have something that you monitor vitals with?
Gonna need some numbers to help you out, otherwise it's a crapshoot for the most part.
Don't run the batteries down, whatever you do.
Old Aug 26, 2017 | 09:37 PM
Errols's Avatar
Errols
Ok bud.
The only code that i think matters is the NOx code because the EGR is unplugged.
The NOx code is a P2200.
I don't have anything that monitors vitals.
I have spoken with others and they have said to check the stand pipe for the high pressure oil pump or other related parts.
Old Aug 27, 2017 | 06:22 AM
bismic's Avatar
bismic
P2200 is not a diesel code since you don't have a NOx sensor.
What is the specific EGR code number?
Do you have an early 04 or a late 04 - you can tell by the location of the ICP sensor (or if you know the specific engine build date).
Monitoring the engine parameters (PIDs) is essential to troubleshooting as Mike pointed out. An ELM (bluetooth) adapter and a phone/tablet App (Torque, Forscan, etc) are relatively cheap. Lots of threads on the monitoring.
Montana Mike
Aug 26, 2014 08:15 PM
fyrbrd
Jun 11, 2010 07:04 PM
fordforay
Aug 29, 2006 07:40 AM
ksubuck
May 7, 2006 07:00 PM
cltcc
1997 - 2003 F150
Sep 2, 2004 12:12 AM
