Forscan question
Old Aug 3, 2018 | 12:00 AM
Run-n-gun's Avatar
Run-n-gun
Forscan question
I used Forscan today to turn off the auto stop/start, change the DRLs, turned off the double honk, enabled Bambi mode, and enabled secure idle. Forscan wouldn’t display the IPC modules, or the DDM or PCM modules I need to finish the display and power mirror changes. Any ideas why I can’t access those modules?
2017 F150 SuperCrew Lariat 3.5EB
Old Aug 3, 2018 | 12:56 AM
ford390gashog's Avatar
ford390gashog
It's the adapter, the adapter I had wouldn't show those either. So I went to a wired adapter with the switch and everything shows.
Old Aug 3, 2018 | 07:33 AM
Run-n-gun's Avatar
Run-n-gun
I am using a wired adapter with the switch and the switch is in the "correct" position. Am I supposed to flip the switch to see other modules?
Old Aug 3, 2018 | 12:06 PM
storage_man's Avatar
storage_man
Forescan should ask you to switch the switch, then it will pick up the rest of the modules. HS first and then MS.
Old Aug 3, 2018 | 01:02 PM
CR172's Avatar
CR172
? When 'playing' around with Forscan, is it possible to "brick" your truck as you can a phone?
Old Aug 3, 2018 | 02:06 PM
PupnDuck's Avatar
PupnDuck
Not in the way you can brick a phone but you should heed the warning in the Forscan instructions to download and save the configuration of every module that Forscan can access. That way if you make a mistake, you'll have the info to go back to the factory configuration.
Old Aug 3, 2018 | 02:53 PM
Run-n-gun's Avatar
Run-n-gun
I was set to auto (by mistake) so it wasn't asking for me to switch. Got it done. Thanks for the help.
Old Aug 4, 2018 | 08:34 AM
vnleclaire's Avatar
vnleclaire
Forscan
You might need to download and install the extended license. I had the same problem with the program not allowing me to access modules.
Old Aug 4, 2018 | 11:58 AM
JDubya88's Avatar
JDubya88
What do I need to use Forscan? Is there a list of things it can do on these trucks?
Old Aug 4, 2018 | 03:13 PM
Run-n-gun's Avatar
Run-n-gun
Here’s a link to the FORScan forum page that links to programming details by vehicle and year. There’s also a “how to” link that I followed to get mine done correctly.
https://forscan.org/forum/viewtopic.php?f=16&t=4393
Skorpion007
Jun 15, 2020 10:01 AM
dynocompe
Dec 6, 2018 03:55 PM
Cactusroadster
Modular V10 (6.8l)
Oct 6, 2018 03:10 AM
Genesis
Dec 23, 2010 02:42 AM
RICHMC54
Dec 5, 2004 05:18 AM
