6.2L V8 Discuss the 6.2L V8
Transmission temps
Old 07-31-2018, 08:45 PM
JTPioneer's Avatar
JTPioneer
JTPioneer is offline
Transmission temps
2012 F250, 6.2 with 3.73 gears towing 10K. It has been quite hot and I was towing my trailer up Snoqualmie Pass and monitoring the digital readout for the transmission temperature. it got up to 223 degrees which is hotter than I have ever seen it. I noticed that the analog transmission temperature gauge barely moved at all and was well below red line. I know it works because it reads low when starting up after sitting overnight.
Anyone else notice this? What transmission temp is considered red line?
Old 07-31-2018, 09:02 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Those temps are fine, some of us see near 240 towing heavy.
Old 08-01-2018, 05:43 AM
dnewton3's Avatar
dnewton3
dnewton3 is offline
I don't know where the "red line" value is set; my guess would be 275F.
230F is not "hot" for any oil. Most engine and tranny temp testing done for SAE studies is focused on 250F as a sump temp; held there on purpose to simulate typical high-load stress.
Old 08-01-2018, 08:03 AM
rvpuller's Avatar
rvpuller
rvpuller is online now
I've never seen mine that hot but I don't monitor it all the time, 217 is the hottest I've seen to date. One thing to check is the space between the cooler and radiator because it can become blocked with bugs and other junk. After the first time I found it pluged I clean it regularly with hose.
Denny
Old 08-01-2018, 09:12 AM
acadianbob's Avatar
acadianbob
acadianbob is offline
Yes, 213 for me pulling to the Eisenhower Tunnel. Pulling 11K 5er. 6R100 tranny.
Old 08-01-2018, 09:22 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
In the older transmissions, 250F was the hottest you wanted to run. The tow/haul light would flash and an overheat code would be stored at 275F. Before I left Ford in 2007 we were discussing raising that temp. I think they did raise it after I left.
Old 08-01-2018, 11:36 AM
rvpuller's Avatar
rvpuller
My highest temp was pulling Wolf Creek Pass in CO. With the way the coolers are setup in the 6.2 with the 6 speed you just aren't going to see temps much higher than the 220 range unless something is wrong.
Denny
Old 08-02-2018, 12:52 PM
JTPioneer's Avatar
JTPioneer
Thanks for the info - nice to know that my concerns are unfounded.
Old 08-05-2018, 08:58 PM
tony montana 42's Avatar
tony montana 42
tony montana 42 is offline
My 2017 really never get above 210 while towing my travel trailer. But haven’t had it in the mountains either
Old 08-05-2018, 09:00 PM
tony montana 42
Old 08-05-2018, 09:01 PM
tony montana 42
Here is my setup installed new wdh today and still have to dial it in. 6.2 tows it great
Old 08-05-2018, 09:31 PM
JTPioneer's Avatar
JTPioneer
On flat roads and rolling hills my transmission temps are in the 190's Towing up a long 6-7% grade is a completely different animal, especially on a hot day. Nice to know that the 6.2 has been engineered to handle this with ease.
Old 08-05-2018, 09:43 PM
rvpuller's Avatar
rvpuller
In the last 5 years I've pulled in every condition you can imagine and it hunts between 197 and 210 unless it's a real hard pull and then 217 is the highest I've ever seen it, great set up.
Denny
Old 08-07-2018, 10:46 AM
crewzer's Avatar
crewzer
crewzer is offline
Exclamation
Originally Posted by JTPioneer
2012 F250, 6.2 with 3.73 gears towing 10K.... What transmission temp is considered red line?
I found this discussion in the 2018 BBAS SEIC / PTO manual (page 3) about the AT temperature to be interesting:
HTH,
Jim / crewzer
Old 08-08-2018, 08:38 AM
acadianbob's Avatar
acadianbob
HTH,
Jim / crewzer
So, I wonder why there is no temperature given for the top of yellow/bottom of red . . . . Still leaves you wondering . . .
Quick Reply: Transmission temps
