Excursion
Old Jul 31, 2018 | 03:10 PM
cvictor's Avatar
cvictor
Excursion
I need help in what is a fair price for a shop to charge you for installing a HPOP on a 2004 Excursion 6.0
Thanks
Old Jul 31, 2018 | 04:25 PM
MrMajestyk's Avatar
MrMajestyk
Welcome to the FTE cvictor
For a quicker reply, I'd post this in the ' Excursion - King of SUVs ' thread
https://www.ford-trucks.com/forums/forum29/
Old Aug 4, 2018 | 11:35 AM
Stewart_H's Avatar
Stewart_H
Moved to the 6.0L forum.
Stewart
Old Aug 4, 2018 | 02:10 PM
bismic's Avatar
bismic
The HPOP alone can cost $1000 or more for a good one (and you want a good one!).
The Dieselsite Adrenaline pump is excellent.
https://www.dieselsite.com/2003-2004...lpumphpop.aspx
CNCFab sells one that has a good following also, and is cheaper.
https://www.cncfab.us/product-catego...-engine-03-07/
I wouldn't go back w/ OEM.
Book time would depend on whether or not your intake has to be removed, and I assume yours would have to be removed (03 to early 04 engine).
IIRC it would be 6-7 hours. Someone else will come along w/ a more confident answer!
It has been awhile since I had any work done. Labor was around $125 an hour.
Main thing is to find a good and honest shop!
Old Aug 4, 2018 | 02:18 PM
navistarnut's Avatar
navistarnut
Mark,
Interesting link from CNC fab, I have never seen thier products.
Appears it's more of an OEM pump look to me, they just do a better job of rebuilding cores maybe?
I would use an Adrenaline myself if needed, but a reliable reman for quite a bit less would be nice.
I think all the bad out of the box Ford remans and others have left a stain.
I would give a shop that amount of time for sure.
Old Aug 4, 2018 | 02:21 PM
bismic's Avatar
bismic
CNCFab does like the old 7.3L Terminator upgrade. They take an OEM pump and upgrade the weak components. Lots of good reviews, but I don't have any personal knowledge or experience with it. Lots of people on the Org have used it.
Old Aug 4, 2018 | 02:23 PM
bismic's Avatar
bismic
I was re-reading some old Ford training stuff and came across a reminder that if you have a bad HPOP, you should also remove the oil cooler and clean out the oil reservoir under it (might have some metal residue that could contaminate a new pump). They warn that if there was any metal that was "blown back" into this reservoir, it could cause issues in a short time w/ a new pump. I wonder ....
btw cvictor - for the parts you will also need a gasket set and also may need a new ICP sensor and ICP wiring harness.
If it is a late 04 engine, you may also need the updated dummy plugs and standpipes.
C1959palmer
Jun 17, 2019 10:59 PM
Stewart_H
Apr 3, 2012 08:50 PM
i eat hybrids
Jul 21, 2009 08:43 AM
i eat hybrids
Aug 27, 2007 07:54 AM
