I have a 2015 350 lariat CC LB and the alarm goes off at random times. All doors are locked and no one is near the truck. I can go weeks and not act up and then it will go off several times in a night. Any one else have an issue? Ideas on what to check?
Are one possibility. If it is only happening at night. They keep setting off the alarm hoping you will get frustrated and leave it off for the rest of the night. Anyway, that's the way we figure it happened for a buddy of mine. He thought his alarm was acting up also.
I have a 2017 f250 Lariat and is doing the same thing. I am leaning to the hood latch sensor because my truck was serviced yesterday and the alarm went off last night. Coincidence?? The hood hadnt been opened in a while which points me toward the sensor. Amazon sells the latch with sensor for $97 but I want to make sure that is the problem. Would you know if I diosconnect the plug on the latch sensor will that stop the false triggers? Good luck. Thanks.
