Need help please
Old Jul 24, 2018 | 07:36 AM
Joshua Frazier's Avatar
Joshua Frazier
Need help please
Hi everyone i am new here and i need help i have a 1996 f250 7.5 and my problem is it dies out when i am driving but most of the time its when i have half a tank or more but if i disconnect the battery for 10minutes it fires back up i need help it makes me late for work
Old Jul 24, 2018 | 08:04 AM
subford's Avatar
subford
Do you have two fuel tanks?
If so does it do it on the other tank?
Could be one of about four things.
1. Fuel pump
2. PIP sensor
3. Ignition coil
4. PCM
You need to check to see if what codes you have stored in the PCM memory (CM).
The codes may tell you what is wrong.
So you need to check for fuel pressure and spark when it dies after checking the codes.
Old Jul 25, 2018 | 05:09 AM
Joshua Frazier
Yes it has 2 tanks it has a new pump in the front tank i dont use the back tank cause it leaks i changed the ignition control module plugs wires cap rotor
Old Jul 25, 2018 | 08:04 AM
subford's Avatar
subford
Well the black ICM very seldom goes bad not sure why you would change that. If you installed a gray ICM or a non Motorcraft ICM then put the black ICM back in that you took out.
Changing the plugs, plug wires, Distributor Cap and Rotor are OK if bad but would not help with your problem.
Other than that what I posted above in post #2 still applies.
coleman12
Nov 13, 2015 02:09 PM
nisswa
Nov 13, 2011 03:00 PM
ncline
42
Jun 12, 2008 10:43 PM
randrm
Aug 7, 2007 05:59 PM
kellar
Jul 9, 2005 02:23 PM
