Need Help!!!
Old Jul 9, 2005 | 12:13 PM
kellar's Avatar
kellar
Need Help!!!
I have a 1994 F-150 with a 5.0 5spd. It ran perfect until a couple months ago it started to spit and sputter after driving for about an hour. Then after it sat overnight it ran fine until it got warm. Now it only takes a mile or two before it starts to spit and sputter. I have to rev the gears to make it run half decent. I changed the plugs, wires, distributor cap, rotor, coil, MAP sensor and ICM. I changed the fuel filter and then after driving the truck the fuel filter was dirty again so I dropped the tank and drained it. There was alot of dirt in the tank so I thought that was the problem but it still doesn't run any better. What could the problem be?
Old Jul 9, 2005 | 02:23 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you checked the computer for trouble codes?
here is a good link for instructions if you don't know how:
http://www.thorssell.net/hbook/eectest.html
