Looking for a Brake Controller
Old Aug 1, 2018 | 11:23 AM
brandon_oma#692's Avatar
brandon_oma#692
Originally Posted by Terryd91
the braking with the pedal is proportional so it will start low than ramp up to what its set at when the accelerometer senses the truck starting to decelerate. I had to remount mine because it was not level the first time and did some weird stuff. After that it worked fine, my tires would lock at 7v so i set them to 5.5, it would apply close to 5.5 if you stomped on the brakes. The higher boost will apply more initial voltage. I would try and verify at the plug that you are getting what it says its putting out.
Will try that
Originally Posted by BPofMD
If everything else fails to satisfy you - have you tried calling the company? I have seen they will bend over backward to help you.
I did years ago and was told that is how it is supposed to work. The explanation was something like this."My truck was not slowing fast enough to apply more trailer brake." I do turn it down for the 7k carhauler when it is empty but other than that it is on max.
I will test this out again when I bring the camper home after this weekend. I can also try adjusting how it is mounted it is pretty straight but may not be perfect.
Old May 12, 2023 | 09:41 PM
SuperStroked's Avatar
SuperStroked
1st Gear
Integrated Brake Controller/Outfitter Switches 1999-2002
I have a 2001 f-350 that already had the outfitter switches and factory digital brake controller installed. I would like to do this with my 2002 f-250 as well. What wiring would they have done to make this work? The brake controller and outfitter switches are plugged directly into wiring harnesses and not hacked up…. Any help would be greatly appreciated. I have a fomoco brake controller and outfitter switches to start. Thanks in advance from North of the boarder.
Wilmax
Dec 16, 2012 10:24 AM
bama210
Modular V10 (6.8l)
19
Mar 13, 2009 10:58 AM
Wookie35
Feb 27, 2008 08:54 PM
mikewrt
Nov 9, 2004 05:42 PM
