will 160 30 injectors help towing?
I'm a little over 110k miles with my 160/30's. Cody did the tuning and I'd have to say, that I have no issues with EGT pulling this.
- If I'm pulling all the injectors why not get new ones at 305K miles. Bought new 160/80 injectors (I felt that remans were too much of a roll of the dice for me).
- Going under the valve covers. New valve cover gaskets and harnesses.
- I have to pull the glow plugs so new ones all around (they were original).
- Leaking injector cups. Replaced all 8.
- Coolant drain/flush/refill since I had to replace the injector cups.
- It's my daily driver so can't risk down time...bough a Hydra.
- Had to make sure I passed smog if I got caught with the Hydra...had my PCM flashed.
- Needed custom tunes. Bought tune bundles from 2 different vendors.
- Batteries died. New batteries.
- More power on tap. Bought traction bars to prevent driveline damage from "frisky" driving episodes (haven't installed yet).
- Needed more air to feed the injectors...bought S&B intake (already rebuilt the turbo a few years ago).
- Installed gauges (EGT, trans, boost, fuel) to monitor non-PCM items
- Run Torque Pro to monitor PCM items
Things I still have to do/watch: driveline (original u-joints), transmission (it's a stock 4R100), and every drop under the truck (I look every time I walk up to the truck and when I walk away). Who knows what new and curious leak I've developed (I currently have 3 leaks I'm chasing...2 related and one unrelated to the engine).
Cha-freakin'-ching! Granted some was self-imposed but some was either work found once I opened it up or replaced things that were 14 years old that may (or may not) do so well once disturbed and re-installed. That's the big stuff I did and doesn't include all the small things or tools I had to get to perform the work (e.g. Mityvac with various pieces to evacuate the cylinders).
With stock sticks I could drive my truck and only have to monitor a parameter or two and have fun. Now that it's putting out a lot more it requires more attention on my part. Depending on the tune depends on how much I'm watching my gauges. I was considering a 38R but changed my mind. I'm not interested in higher-than-normal pressures (boost, ICP, etc.) as I do want this block to last me until 500K.
To do this I've come up with my personal "Rule of Three" that I'm going with for now. That means no more than: 3ms PW, 3000 psi ICP, and 30 psi boost.
I was dead-set on single shots for years. When it was time to pull the trigger I did a LOT of research. I heard some compelling arguments for hybrids which made me consider them but in the end I got 160/80 single shots. I learned a lot during my research that I hadn't considered before so it was almost by dumb luck that I ended up with the injectors I had been dreaming of. I already has some things in place which allowed me to make the single shot decision. Had my truck been set up differently when it was injector time I might have gone a different route.
You can read about all of our experiences and find out what we liked or didn't. These are mostly personally biased. Some are happy with stock injectors with a T4 setup for the turbo, some are happy with hybrids, and some are happy with single shots.
Injector shops and tuners have worked with multiple setups and can tell you what worked well and what didn't for certain applications as well as customer satisfaction. Each vendor you talk to will have brands that they prefer to work with or have had better success with so ask about that too.
Whatever you do make sure it will be "compliant" with any state inspections/smog check requirements you might have.
Just my .02
