Wire Idetification Help!
Old Jul 22, 2018 | 06:45 PM
86F250 460's Avatar
86F250 460
Hey all I'm in the process of trying to clean up my engine bay and have found a mess of wiring cut off, bad insulation etc etc. and I've been trying to Id what everything is and have a few things left and was wondering if anyone had any ideas.
This is located on the drivers side hangs right next to the brake booster and enters the firewall in an opening close to the center of the firewall with what looks like a vacuum line? and enters a taped loom with that vacuum line
Wires from above connector.
This connector is in a loom with wires that heads down under the cab im not sure where its supposed to be as its just been dangling.
This connector hangs on the drivers side area above the wheel well area. green with white tracer and black wire I believe
Any help would be greatly appreciated.
File Type: mov
File Type: mov
Old Jul 22, 2018 | 08:24 PM
ctubutis's Avatar
ctubutis
The 2nd one should be for the BRAKE light on the dash, it should plug into a switch in the brake system differential valve.
Old Jul 22, 2018 | 09:02 PM
86F250 460's Avatar
86F250 460
Ahh makes sense as the previous owner installed all new lines and a new proportioning valve that has a hydraulic parking brake so no place to plug into. Thanks
Old Jul 23, 2018 | 02:20 PM
Franklin2's Avatar
Franklin2
The wires below look like they go to the cruise control found here in this link on page 136. Speed Control - Gary's Garagemahal (the Bullnose bible)
Old Jul 23, 2018 | 04:33 PM
86F250 460's Avatar
86F250 460
Cool thanks I have a similar diagram in some computer manuals I bought off lmc but they don’t show the connectors or pictures so hard for me to tell.
timmyboy76
29
Jan 27, 2017 10:51 AM
hharris8
Aug 3, 2016 02:01 PM
Jarrett Campbell
May 13, 2016 10:22 AM
queen of spades
Mar 31, 2015 11:15 AM
drizzie27
Mar 28, 2012 06:08 PM
