Electrical Adventures
Old May 11, 2016 | 07:46 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Ok so I decided enough was enough with the truck and that I would finally get around to tracking down my electrical gremlin.
I repaired three completely exposed wires (one was the main power wire off of the generator) and replaced a few butt connectors with solder and heat shrink and one especially frustrating length of wire with three butt connectors holding the thing together
So here are some pictures of loose wires I found while rooting around in there. I know it is dirty, but all the oil is old. I plugged the leaks when I bought it and never got around to cleaning.
Wires everywhere. I need to loom this mess.
First two danglers. They come out of the connector in the next picture.....
Two wires on the right are loose, the one on the left is connected to..... next picture
Right here. Can I cut the other two off? Should I just zip tie them to the fender?
Passenger side firewall, single wire connector comes out of main harness and I can't see anything it should be attached to...
Another look at the single connector.
I will have some other pictures of the other connectors that aren't attached to anything probably tomorrow morning.
Thanks to everyone for the help!!
Old May 11, 2016 | 08:12 AM
hickory1991's Avatar
hickory1991
I think that single connector is for an under hood light.
Old May 12, 2016 | 11:39 AM
brianto79's Avatar
brianto79
X2 on the single connector, don't worry about it. Check all grounds.
Old May 12, 2016 | 01:25 PM
Jarrett Campbell
[QUOTE=X2 on the single connector, don't worry about it. Check all grounds.[/QUOTE]
Thanks guys!
How many grounds are there on this truck? Or better said, how many should there be?
I've been really busy and away from the house the last few days, haven't had a chance to work on anything. I'll hopefully get to it after I get back from Canada next Friday.
Old May 12, 2016 | 02:17 PM
4x4slik's Avatar
4x4slik
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
link to wiring schematic which I believe has locations of grounds also.
Old May 12, 2016 | 04:24 PM
Jarrett Campbell
That link is solid gold. Thank you!
Old May 12, 2016 | 09:27 PM
4x4slik's Avatar
4x4slik
Yeah, I have a few i keep in a special bookmark folder. I just wish I had a giant format printer to print them out so I can read them.
Old May 13, 2016 | 07:58 AM
Jarrett Campbell
I could plot them at work. We have a 34" printer. Would a 22x34" print be big enough? hahaha
For real, if you want me to I can print it and send it to you! Just PM your address and the diagrams you want and I'll get it in the mail
Old May 13, 2016 | 08:07 AM
HIO Silver's Avatar
HIO Silver
Laminated 11x17 sheets are more handy.
Old May 13, 2016 | 08:41 AM
mikeo0o0o0's Avatar
mikeo0o0o0
In the first pictures, that looks like the engine gauge feed harness. One wire should go to the "+" side of the coil. From the pictures I would say that there was an issue with the ignition coil resistor wire sometime in the past and it's been bypassed with the external resistor. The two "danglers" should be for the oil pressure sending unit and the temperature sender.
Old May 13, 2016 | 09:07 AM
Jarrett Campbell
That would make a lot of sense. There is an aftermarket oil pressure, voltage, and coolant temp gauge in the truck and the stock ones don't work. Thanks Mike!
As far as the ignition coil resistor, is the external one ok or should it have been replaced?
Old May 13, 2016 | 09:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0
As long as it's working okay, you aren't going for a concourse restoration, or you're not obsessively OCD, you can leave it. Replacing the resistor wire that it bypasses is a real pain. To do it to concourse standards would pretty much mean replacing the underdash wiring harness .
Old May 13, 2016 | 10:05 AM
Jarrett Campbell
I think it is going to be left the way it is.
Old May 13, 2016 | 10:21 AM
mikeo0o0o0's Avatar
mikeo0o0o0
obsessively OCD
I re-read my answer, I think that's a pretty redundant statement .
Old May 13, 2016 | 10:22 AM
Jarrett Campbell
My dad always says he is CDO.
That's OCD in alphabetical order, and I think he's right.
Wes444
Oct 3, 2017 06:36 AM
Tugly
13
May 2, 2017 11:48 AM
drizzie27
Mar 28, 2012 06:08 PM
Fishin76
Oct 21, 2009 09:54 PM
black58
15
Apr 5, 2009 08:31 PM
