Sponsored by: Real Truck
2016 wheel interchangeability
Old Jul 21, 2018 | 07:45 PM
wvdave's Avatar
wvdave
Exclamation 2016 wheel interchangeability
I have a 2016 F350 with stock 17x7.5" wheels. I would like to put a set of 2018 stock wheels on it, they are 18x8". I would like the 8" wheel so I can run a Cooper AT3 XLT with a 4080 E load rating. Can I do that with no problems?
Also, I have a set of take off Cooper SST Pro's that I would like to put on a 17x7.5" factory steel wheel for looks and to run while I'm not towing. What year factory wheels will fit my 2016 F350? Any, as long as they are 8 lug?
Old Jul 21, 2018 | 08:48 PM
texinwa's Avatar
texinwa
2005 and up
Old Jul 21, 2018 | 09:37 PM
wvdave's Avatar
wvdave
thank u! even the 2018 18"?
Old Jul 22, 2018 | 08:44 PM
fordman19762003's Avatar
fordman19762003
Yes. I believe the only difference with the '17+ wheels is the center hole is larger because the rear axle hub is a larger diameter
Old Jul 24, 2018 | 09:14 AM
seemoremud's Avatar
seemoremud
i believe it's only larger on the 250 Max tows and F-350s. 17+ 250s still have the old Sterling axle, unless they had the max tow option, then they get the same new axle as the 350 srw, and then the duallies have their own axle. . I am 99% that's how they're equipped.
I put a set of 18" pvds off a Lariat 250 diesel on my '16, hub bore waa identical
rezrocket6.0
Mar 5, 2012 06:10 PM
Bpayton
Oct 26, 2011 05:22 PM
EatBeef
Nov 9, 2009 08:13 AM
86diesel-
May 9, 2006 09:17 PM
