Alignment numbers advice needed
Old Jul 22, 2018 | 10:32 PM
GoinBoarding's Avatar
GoinBoarding
Which truck is this? I had some Moog adjustable bushings that enable up to 3.25 degree adjustment on a Dana44 ttb that I used for a 1.5" level (cc844 coils). One side I went with a fixed 2.75 and the other side needed more, so I kept the adjustable in there. I should have used a rack but instead I just got the toe set, used a level for camber, and did trial and error for caster based on pull. A bit time consuming...
Old Jul 23, 2018 | 12:19 PM
sandymane's Avatar
sandymane
They are for the 91 F 250 in my sig. Notice also the chart for the 2wd says "do not go past 2 degrees negative". Sandy
Old Jul 23, 2018 | 02:22 PM
GoinBoarding
Gotcha, different axle, disregard my post.
I'm on my phone, don't see signatures.
Old Jul 23, 2018 | 02:55 PM
sandymane's Avatar
sandymane
Thanks anyway. Sandy
sandymane
Oct 6, 2017 07:20 PM
Thumper19
Oct 12, 2011 06:33 AM
B Big
Sep 1, 2010 07:56 PM
smashclash
Jun 18, 2010 06:16 AM
gbeach
Jun 19, 2007 09:21 PM
